Greddy Turbo Questions thread....
Originally Posted by NFRs2000NYC,May 29 2008, 09:07 PM
It's all in the tune. A good tuner should have no problem getting rid of it.
also, what about the heat gauge no longer working? What could that be?
^^^ That seems very lean!!! you need to be about 11.0 - 11.8 to be safe. NA you can get away with it leaner but because of the heat created by the turbo you want more fuel...
More heat could have caused you EGT gauge to fail from extreem egt's.
I would recommend an tune ASAP! GL
yea definitely do not go WOT if you see anything over a 12.5...
ideally i think a safe area to tune is in the mid 11 range (thats what we did at least..) we did try to lean it out into the 12's a bit but there was no power gain at 7psi, which is what i'm running right now.
please correct me if i'm wrong!
It was tuned a few weeks ago..
I contacted the tuner. He told me that it could be the stock ECU trying to take over... wtf is that possible?
Is there a way I can adjust the emanage to make it a little more rich?
Did you recently disconnect your battery?
