Help
Old Mar 21, 2008 | 02:34 PM
secrets2k's Avatar
Default Help
So i put oil in my car till it read to the H but my oil light is on anyone can help me with this?
Old Mar 21, 2008 | 02:35 PM
03silver2000's Avatar
prolly a bad oil sending switch
Old Mar 21, 2008 | 02:47 PM
Reborn56's Avatar
What kinda ems are you using?
Are you boosted?
Old Mar 21, 2008 | 02:58 PM
05TurboS2k's Avatar
agree, check switch. I trust a dipstick before a switch.
Old Mar 21, 2008 | 03:06 PM
secrets2k's Avatar
yes just got done with it first time with oil in it iam using AEM EMS
Old Mar 21, 2008 | 07:51 PM
Soul Coughing's Avatar
your stock oil pressure sensor doesn't go through EMS. It is a simple switch that grounds itself when it reachs 20-30 psi! Either you didn't reconnect the screw on the end of the sensor, it is broken, or there has been catastrophic failure... the usual signs would be present though with catastrophic oil pressure failure though...
Old Mar 21, 2008 | 08:00 PM
Reborn56's Avatar
actually come to think of it i didnt connect the screw in all the way, it was loose and i was getting the check oil light coming on and off all the time.
Until i tightened the screw
Marcus
Old Mar 26, 2008 | 08:30 AM
secrets2k's Avatar
the screw is tighten all the way down has enough oil but the light stays on......it runs fine
chrispayze
Aug 31, 2017 12:07 AM
08s2000CRbackinblack
Jan 30, 2014 08:45 AM
Spoolin
Aug 12, 2011 08:44 PM
Phillie
Jun 15, 2007 04:20 PM
PeanutButter
May 10, 2007 12:43 PM
