How much HP for 11 seconds?
I've come to the conclusion that one would need a transmission and differential kit upgrade to run reliably and faster in the 1/4 mile. The HP is not the issue, the issue is being able to put that power to the ground without having to worry about breaking the tranny and/or differential.
There you go using that "reliably" word again. If the forum was more active you would ten reply's from guys saying I do the 1/4 in X and I never blew a rear end. Of course you do not hear from the 100 that did.
Anyway I could not agree with you more.
I made 507 with my P-Tuning 3076 on evans higher reading dynapaks(closer to low 400`s on a mustang) with a semi hurt cylinder 2, spinning through 1st on hankook rs-3 I did 3 back to back runs through out the day and every single run was 12.3-12.5 at 116-117mph. Awful 2.11 60` hurt me alot. If I checked tire pressure, lowered the launch control, and got to the 1.7-1.8 60` I am confident it would be a high 11. I wouldnt get to caught up on HP numbers to run this time... perfect example termination makes 355hp and I made 507 and he ran 10mph faster trap. Just make sure you have your suspension setup and a 58-62mm turbo setup and you be in the 11`s for sure. Oh btw 4th pass I snapped an axle so beware... it will happen so have the trailer ready haha
