Ignition options? Coils, plugs and stuff.
Old Jul 12, 2013 | 02:08 AM
  #41
B5254T4's Avatar
Originally Posted by boostedf22c
Originally Posted by B5254T4' timestamp='1325005092' post='21265888
Can´t make up my mind, please help me out guys. Really prefer to keep things simple without extra parts and boxes but will go that route if needed.
Then the AEM smart coils are your best option. The price is right, no additional boxes, and we have put them through their paces for sure. No smoke and mirrors here. 100's of 1/4 mile hits, lots of dyno pulls, and actually made the power that others have claimed. It's the best ignition solution I've used to date. And this is proven by the results no just my opinion.
If you want to spend more on other stuff it's out there, but no need too.
The one thing you'll have to do with the smart coils is a mounting solution.
We run 8's or 9's, NGK Iridium
Sounds like a good solution, like the BAS idea as well but bigger coils sounds like a better idea than raped OEM ones. Probably better coil cooling and longer life on the AEM´s.
Old Jul 12, 2013 | 08:19 AM
  #42
redboost10's Avatar
Compared to the cbr coils?
Old Jul 12, 2013 | 08:27 AM
  #43
passmans2kny's Avatar
how come carey is the only persone to get the aem smart coils to perform? havnt others tried these and they didnt work?
Old Jul 12, 2013 | 09:03 AM
  #44
indi00's Avatar
I got it working fine. Had problems with the custom ignition coil wires I made. It was custom crimped, so every time I go pull the coil wires out, the wires would sometimes come loose at the crimp causing misfires. I would have to cut and re crimp again. I just need to come up with a better solution. I drove a couple months with the AEM coils.
And to add to that, my car is lowered on springs and recently started getting vibration under acceleration in third gear under boost. I attributed that to misfires. I added spacers to the differentials and the acceleration under boost is smooth now.
I went back to the boost a spark because my mounting solution just sucked. It makes the engine bay way too cluttered. It needed professional wiring like Carey's. And for my application, I didn't really needed the AEM coils.
Old Jul 12, 2013 | 10:37 AM
  #45
B5254T4's Avatar
No meant the OEM ones. Like the CBR idea but don´t want any extra boxes, looking for beefy upgrade coils.
Old Jul 12, 2013 | 11:08 AM
  #46
beaudin223's Avatar
ok so if you run under 400 whp u an still use ur oem coils ?
Old Jul 12, 2013 | 11:16 AM
  #47
camuman's Avatar
it will be fine.
Old Jul 14, 2013 | 03:08 PM
  #48
Keith P's Avatar
Any info on using cbr coils??
Old Jul 14, 2013 | 07:01 PM
  #49
redboost10's Avatar
What info are you looking for?
Old Dec 11, 2013 | 06:50 AM
  #50
Keith P's Avatar
Wiring info. Will stock cables work? Any info would help.
Making a mounting bracket isn't too hard.
