Inline Pro Engine #3 - knocking after 1 track day. It's over.
I’ve only been reading and not chiming in at all, but we really need to be fair to Inline Pro here. The OP’s first rebuild from IP blew up from poor tuning, which is on the tuner, regardless of what the car owner was told by the engine builder. The tune probably wrecked the original engine too. I’m not trying to defend one side or the other, as I also know the frustrations of built engine problems. I think that Inline Pro should at least have the opportunity to remove and disassemble this engine so they can figure out what happened and make sure it never happens again. Ultimately it’s your car and your money, but this story has been pretty crazy. I definitely don’t wish this situation upon anyone.
I simply decided to do a refresh of the motor as I saw/read some F22 refresh options that inline pro offered, just due to the mileage of the motor and my future plans of tracking, I thought it a good idea. This is when it all started.
Inline pro told me on motor #1, don't worry, the current tune will be fine, don't bother getting it retuned... despite them offering their own tuning services!! Motor blew for obvious reasons, I'm ashamed for not knowing better but I trusted the supposed #1 shop for F engines.
Motor #2, rebuilt this time with new(to me) block, oversized CP pistons, Inline pro rods, ARP everything. Inline pro tuned the car this time, I broke it in on their tune per their advice for about 5-600 miles. I then (with their blessing) trailered the car for a full dyno tune at evans. The pistons scored the cylinder walls so bad on the dyno the motor was blowing the dipstick halfway out of the hole at WOT. Got home, scoped the cylinders and that was all she wrote for engine 2.
Now #3 is another new (to me) block, 10:6:1 CP pistons, inline pro rod, ARP everything, evans tuned again and here we are a year later.
#2 I really never received an answer as to what the root cause was. They just rebuilt it on their dime and said it was fixed since it was lower comp pistons this time for safety.... even though all I was trying to do this entire time was run a 3.4'' pulley on a brand new SOS stage 2 system - total cookie cutter build.
Here's the list of the main components in your engine (short block).
Custom FRM 87.50mm bore 10.6:1 compression Turbo Forged Flat Top CP pistons with rings and wrist pins
Inline Pro HD H beam connecting rod set with 3/8" ARP2000 bolts
Stock F22C crankshaft
Piston to wall clearance .003"
1st ring gap .022"
2nd ring gap .026
*If you're trying to reference or compare these clearance numbers for build tolerances, please keep in mind this is an engine that utilizes Honda's "Fiber Reinforced" (FRM) sleeves. Traditional engines with iron sleeves use different tolerances for their builds.
