Inline Pro Engine #3 - knocking after 1 track day. It's over.
at best it's a non-off-the-shelf piston, but there's literally no history of that coated CP being reliable. they ****ed up with that for sure. mahle is the only make that has known street miles on honda FRM with somewhat predictable behavior. for us s2ki guys, a dude named wadzii laid out the recipe for him that works. he goes 0.002-0.003" piston-to-wall clearance IIRC. i also have a BNIB set that i bought years ago for 100$.
also 87.5mm is beyond the bore limit of the stock sleeve. it should work fine (there's plenty of FRM material) but i think 87.25 was max and beyond that was experimental at best.
I think if you contact IP and let them build you the engine with new sleeves, you won't have any more issues. I believe the whole problem is stemming from the FRM cylinder walls and the CP pistons not working together properly.
then clean everything to make sure bearing material doesn't contaminate the new engine. also i would opt for a known-good oil pump. bearing material will likely not hurt the f20 oil pump, but for the 3-400$ it's easy insurance to get a new one.
Regardless youndont really see reliable setups with stock sleeves and aftermarket pistons. Thats why no one really does it and I think everyone including me is wondering why they advised him to go this route. Besides they know damn well a stock motor is stout at anything under 600whp.
Aftermarket sleeves add another failure point (sleeve sinking, shifting, leaking, etc). I'm not saying it doesn't work, but I can understand the desire to stick with stock sleeves. I've seen plenty of problems with sleeved motors to know I'd avoid a sleeved block if at all possible.
