inline pro relocation question
had to pull my relocation to get to something and stupid me forgot to mark the lines and which way they go.
can anybody help me out? i need to reconnect them and dont want to mess up anything.
Ok, I'm just re-torqueing the _leaky_ relocator kit myself. Stupid thing!
I had a new motorcycle oil filter laying on the shelf after I sold the bike. So I cut it to see how it works, and to trace/figure out how to install these hoses.
Oil flows from the perimeter holes inside the filter, then through the filtering element, and to the outside through the center hole. Most filters you'll meet are that way, good way to double-check it is to look at the underside of the oil filter and the perimeter holes will have a rubber flap inside. That's sort of a check valve to make sure oil doesn't back out if the filter is really clogged up.
Now then, your puck that mounts to the block where oil cooler assembly used to be has 2 threaded holes (TH). They're _not_ symmetric. They're kinda offset to one side.
-The TH closer to the edge is the oil feed.
-Accordingly, closer to the center is oil return.
From sandwich, TH at the edge goes to the TH at the edge of the filter-mounting puck.
from sandwich 'center' TH hose goes to the center TH of the filter-mount puck.
Good luck!
Good luck!
s20004lifehomes
May 18, 2010 06:21 PM
