inline pro relocation question
Old Nov 5, 2008 | 06:02 PM
TelosHedge's Avatar
Default inline pro relocation question
had to pull my relocation to get to something and stupid me forgot to mark the lines and which way they go.
can anybody help me out? i need to reconnect them and dont want to mess up anything.
Old Nov 5, 2008 | 06:29 PM
kutsujula's Avatar
i think theres a picture on there website isnt there/
Old Nov 5, 2008 | 06:33 PM
TelosHedge's Avatar
no not of the kit installed. its hard to see in some pictures because the lines disappear underneath the crossmember so you cant tell where they go.
Old Nov 5, 2008 | 07:12 PM
Kirpich's Avatar
Ok, I'm just re-torqueing the _leaky_ relocator kit myself. Stupid thing!
I had a new motorcycle oil filter laying on the shelf after I sold the bike. So I cut it to see how it works, and to trace/figure out how to install these hoses.
Oil flows from the perimeter holes inside the filter, then through the filtering element, and to the outside through the center hole. Most filters you'll meet are that way, good way to double-check it is to look at the underside of the oil filter and the perimeter holes will have a rubber flap inside. That's sort of a check valve to make sure oil doesn't back out if the filter is really clogged up.
Now then, your puck that mounts to the block where oil cooler assembly used to be has 2 threaded holes (TH). They're _not_ symmetric. They're kinda offset to one side.
-The TH closer to the edge is the oil feed.
-Accordingly, closer to the center is oil return.
From sandwich, TH at the edge goes to the TH at the edge of the filter-mounting puck.
from sandwich 'center' TH hose goes to the center TH of the filter-mount puck.
Good luck!
Old Nov 6, 2008 | 06:15 AM
TelosHedge's Avatar
i'm very confused by the last post!
just called inline, they said simply 'mount it up, then run top to top, bottom to bottom'
very simple
Old Nov 6, 2008 | 09:37 PM
Kirpich's Avatar
Ok, then ours don't look the same, I guess. Actually, I don't even know who makes mine.
Old Nov 7, 2008 | 05:53 AM
01spaS2K's Avatar
Here is a pic of mine. Maybe this can somewhat help you if you have not already fixed it.
Just thought I would share the photo.
Nick
Old Nov 7, 2008 | 07:39 AM
TelosHedge's Avatar
i'm pretty sure i've got it right now, but while i've got you here..
what did you use to mount your coolant overflow bottle? i bought my kit used and i dont have any bracketing or anything.
Old Nov 7, 2008 | 09:33 AM
01spaS2K's Avatar
I used the mounting bracket from a early 90's Acura Legend. The bracket was purchased at a local junkyard. Hope this helps.
Old Nov 7, 2008 | 01:07 PM
mys2k3's Avatar
You can cut the piece you need off the existing bracket to mount the bottle then weld it to a new location.
s20004lifehomes
May 18, 2010 06:21 PM
s2000 or 240sx
Jan 4, 2010 04:54 AM
scorchza
Jul 1, 2009 07:57 AM
otbs2k
Apr 20, 2009 01:46 PM
skibum
Feb 22, 2008 11:38 PM
