IP stage 2 progress and help thread
Old May 28, 2010 | 10:33 AM
  #71
D1sclaimer's Avatar
Originally Posted by Spec_Ops2087,May 28 2010, 08:19 AM
I'd def either get a turbo blanket or wrap all of those wires by the vtec solenoid.
Yep, a turbo blanket was apart of my plans.
Old May 28, 2010 | 02:25 PM
  #72
Spoolin's Avatar
That VTEC oil pressure sensor can come off and you can just cap it with a bolt and some teflon tape. The AEM doesnt use the sensor. I believe siadam did a writeup on how to do it. I explained it to him and he made a thread if you want to contact him to find out where to view the thread.
Old May 28, 2010 | 03:01 PM
  #73
Irishflame27's Avatar
is that a journal bearing unit?
Old May 28, 2010 | 03:41 PM
  #74
D1sclaimer's Avatar
Yes.
Old May 29, 2010 | 07:55 AM
  #75
are you feeding with -3?
Old May 29, 2010 | 01:29 PM
  #76
pwrofdrm's Avatar
Nice build...
On a side note, I confirmed today that you can run an oil filter in the stock location without the factory oil cooler in place. I removed my ILP Relocation kit and just put a factory filter on. Fits fine with plenty of room. I am very happy, one less thing I have to worry about breaking or leaking now. This is with an ILP Stg. 1 kit with Garret GT3076r btw.
Old May 29, 2010 | 09:17 PM
  #77
D1sclaimer's Avatar
Originally Posted by pwrofdrm,May 29 2010, 03:29 PM
Nice build...
A log manifold from the stage 1 kit and the tubular manifold in the stage 2 kit are different....
Old May 29, 2010 | 09:18 PM
  #78
D1sclaimer's Avatar
It appears so. The feed line is smaller than my old 4AN nitrous line.
Old May 31, 2010 | 07:05 PM
  #79
D1sclaimer's Avatar
The more and more I mess with and look at the intercooler, the more and more that I don't like it. I have the charge pipes pretty much all touching and have the intercooler lined up with them. This is the highest that I could get it to go. I already have issues with scraping the front bumper so I guess I will have to be even more careful now.
I was looking at more install pictures of the same intercooler and noticed it was like that for other installs as well.
https://www.s2ki.com/forums/index.ph...c=560658&st=75
Heres IP's pictures which I should have noticed that it obviously goes down further than the bumper would.
https://www.s2ki.com/forums/index.ph...ic=643018&st=0
Heres another picture from IP from this thread.
Old May 31, 2010 | 07:12 PM
  #80
Spoolin's Avatar
That intercooler is only about an inch taller than my IP 800 hp intercooler and mine fits perfect with about 1/2" of gap between the bottom of the intercooler and the lower plastic cover. Yours shouldnt be hanging that low I wouldnt think. Is there absolutely no way to move it up about 2 more inches?
