Kpro Launch Control & Full Throttle Shift Setup
Old Oct 2, 2009 | 03:58 PM
0piston's Avatar
Default Kpro Launch Control & Full Throttle Shift Setup
I finally just started looking at this Kpro function, and know the dangers of dropping a valve with it... wanted to get the concensus on what settings were most effective. For those who use it, what settings are you using? Any rule of thumb with the amount of fuel enrichment or ignition retard you need for each particular config?
Thanks
Old Oct 8, 2009 | 04:53 PM
spectacle's Avatar
Bump cuz I need info on this too...
Old Oct 8, 2009 | 05:01 PM
rob!'s Avatar
I know you should not be building a lot of boost with the launch control. Its safe to use as long as you arent building a more than a few lbs of boost. I have aem so i dont know the setting but im sure its not too hard to play with to figure it out
Old Oct 8, 2009 | 05:42 PM
0piston's Avatar
I'm building 5.5 bar boost with a 20% retard in ignition 5% fuel enrichment 4500rpm rev limit 3800 activation *caveat this is what happens on my setup so use at your own risk. Just watch out for those twigs called axles
Charper732
Apr 14, 2017 02:37 PM
Spoolin
Dec 19, 2015 09:06 AM
mrscbw
Dec 4, 2012 11:09 AM
siadam
Apr 6, 2009 11:44 AM
JoeyBalls
Sep 14, 2008 07:32 AM
