Kpro Launch Control & Full Throttle Shift Setup
I finally just started looking at this Kpro function, and know the dangers of dropping a valve with it... wanted to get the concensus on what settings were most effective. For those who use it, what settings are you using? Any rule of thumb with the amount of fuel enrichment or ignition retard you need for each particular config?
Thanks
Thanks
I know you should not be building a lot of boost with the launch control. Its safe to use as long as you arent building a more than a few lbs of boost. I have aem so i dont know the setting but im sure its not too hard to play with to figure it out
I'm building 5.5 bar boost with a 20% retard in ignition 5% fuel enrichment 4500rpm rev limit 3800 activation *caveat this is what happens on my setup so use at your own risk. Just watch out for those twigs called axles
Charper732
Apr 14, 2017 02:37 PM
