Mahle s2k pistons
Old Jul 16, 2010 | 06:48 AM
  #41
wadzii's Avatar
Banned
if you were keeping it NA i'd say the brand new block would work fine.. but for a turbo motor, there's no way.
It costs me around $300 to have the block bored/honed.. IMHO thats the way to go.. no guessing there.
Old Jul 16, 2010 | 07:08 AM
  #42
TRBOKEV's Avatar
Yeah I think SOS quoted me 400 or 500 to do the job. i cant remember off the top of my head. I'll have to shoot them a PM or give them a call.
Old Jul 16, 2010 | 07:18 AM
  #43
wadzii's Avatar
Banned
If you want to send the mess to me i can get my guys to do if the price is that much different...
Old Jul 16, 2010 | 09:15 AM
  #44
TRBOKEV's Avatar
That's very cool of you.
I'm putting out some local feelers to see what locals have as far as scuffed bore blocks go.
Do you think pretty much any scuffed bore block could be cleaned up for the .025 oversize pistons? I figure that if it is not deeper than .010-.013 I should be ok..
I just have no idea how deep the "usual" scuffed bore is.
Old Jul 16, 2010 | 09:22 AM
  #45
wadzii's Avatar
Banned
yeah, even if the scratches are a little deeper and dont fully clean up its not that big a deal.. its more important that the bores are round and straight.
Old Jul 16, 2010 | 11:46 AM
  #46
dibi's Avatar
I'm interested in going this route as well. I want to make sure I am understanding this. So for f/i 500 hp I should just have the block rehoned and go with the stock size low comp piston. I have a few vertical scrathes and that should be ok, right. You do not reccomend a rebore and going with the overized piston for a turbo set up.
Old Jul 16, 2010 | 12:25 PM
  #47
camuman's Avatar
Originally Posted by TRBOKEV,Jul 15 2010, 08:22 PM
What about a brand new stock bore motor?
I was planning on buying a new complete shortblock from Honda and just pulling the pistons and swaping in a set of these..
SOS said above that it should be fine on the 87 mahle piston. call chris and ask him to make sure turbo application will be fine.
Old Jul 16, 2010 | 02:09 PM
  #48
TRBOKEV's Avatar
Will do. I've been meaning to give them a call anyway, so I will add this question to the list.
Old Jul 16, 2010 | 02:18 PM
  #49
wadzii's Avatar
Banned
the only reason i say dont go oversize right off the bat for a boosted app is so that you have room to blow it up and try again...
and its cheaper to just hone the block than do a bore/hone
Old Jul 16, 2010 | 03:49 PM
  #50
ScienceofSpeed's Avatar
Former Sponsor
hi guys --
We offer the pistons in both the factory size (87mm) and .25mm over bore (87.25). 87.25mm would be used when the bore needs to be honed due to scratches. We recommend that most used blocks use the 87.25mm size unless either the block is new, has no scratches, and the bore is in perfect circle.
They are offered in 8.9:1 and 9.5:1 static compression. We try to keep the 9.5:1 static compression model in stock.
More detail:
http://www.scienceofspeed.com/products/eng.../Mahle/pistons/
best regards,
-- Chris
