Mase Engineering 6262B Build Thread
Originally Posted by JoeyBalls,Sep 23 2010, 05:58 PM
damn, that cutout is sick, great location. I like the idea of the pressure spring, but I LOVE the way my car sounds when I start it up with the cutout open
, Rice I know
, Rice I know
Well the car is getting closer, I like to think of it as turd polishing
I finally got an AP1 Exhaust system, and I polished the piping and put a fresh coat of paint on the mufflers
I have the High / Low boost switch and boost control working well in all conditions. I have low boost set to waste gate pressure and high set to 20PSI. As for the boost control I was finally able to get the feedback working better so I don't hit boost cut in cold weather. It still needs some work but it is getting closer. Next I am going to try tuning the PI loop boost feedback.
I also had a bad vibration in the car I could not track down. After only a few weeks and maybe 100miles the 60A motor mount bushings failed. I ordered a set of 75A bushings but now the engine vibration is terrible. I am going to make a jig and make a new bracket when I get a chance so that I can used the factory motor mount. This is necessary b/c the cutout will not fit with the factory block bracket.
When I was replacing the knock sensor I was looking at the filter and noticed there was plenty of room to add a PVC elbow so I could recirc the crankcase vent. It only took a few minutes but now there is no more oil smell.
In addition to the above I have the following plans
1.) Take the car back to the dyno to retune the timing. I first noticed that the dipstick would blow out when I was running off the wastegate set pressure and not at high boost. I finally got my knock sensor replaced and what do you know I was seen high voltage at several RPM levels.
2.) The heat from this kit is unreal and I need to deal with it. The valve cover runs a balmy 200-250F and I have had to wrap everything. I am going to pull the mani this winter and send everything in to ATP to have it wrapped.
3.) Fix the dirty old truck smell. First I will add a restrictor to the oil feed b/c there is a constant oil smell and ocasionally smoke. I called Precision and the F and K series motors need an additional 0.030" restrictor. Then after I get the car on the dyno I am going to put a cat back on.
4.) Brace the manifold, there is a LOT of vibration that needs to be delt with.
Let me know what you do with the bracing. There is a slight vibration I am getting right at 37mph. Yeah Mase was right, I am hitting 12 psi now and car feels good. In the spring it will be a full blown pump system, inline pro fuel rail with a tap for a pressure guage and a regulator. I want to see 500whp on e85.
Are those mounts melting from the heat of the manifold?
I have a 2500-3500rpm vibration due to my exhaust. Ill deal with that this week also, how did u recirc the breather hose to the filter?
Who are you having retune it?
i think so... (these are mine before going to 75A)
