Mase Engineering 6262B Build Thread
Old Sep 28, 2010 | 10:37 AM
  #271
Suzuka_Joe's Avatar
Call mase if u have his kit. Precision will send u the wrong restrictor. If u have a ball bearing precision you need 2 restrictors
Old Sep 28, 2010 | 12:01 PM
  #272
s2000442's Avatar
I have tried to call Mase numerous times, left messages, email you name it for help with the restrictor as well as other issues but have had no help. Did you get a restrictor for your turbo from Mase? I have had to go to Fernando at CFT for some help.
Old Sep 28, 2010 | 12:11 PM
  #273
Suzuka_Joe's Avatar
Yea, i talked to mase yesterday and adam is sending me a restrictor today for mine.
Mase is on a trip tuning this week.
Old Sep 28, 2010 | 03:09 PM
  #274
Topillogic's Avatar
Resonance at low rpm, check
Crazy false knock, check
Just had to order a restrictor, check
Resonance/vibration I can live with, it's in a very narrow band around 2500-3000. Kinda sucks for stop go traffic, though. I already have a brace made for the DP from my install, so it may be better or worse than others are feeling. Resonance is a funny thing. I picked up some 60A mounts. They'll probably make it worse but I'm going to swap them out and try it.
I've taken knock count off my Tunerview so it doesn't bug me. But it's too bad it's now not worth logging. Saw 100 counts on one dyno pull.
I wasn't seeing smoke until I lost the cat last week, guys at T1 said order an 0.030 and see where we're at after that. Reading this thread, sounds like that should do it.
Edit: Just realized that came off kinda negative, not the intent at all.
Old Sep 29, 2010 | 05:40 PM
  #275
wait4vtec's Avatar
can i use this instead of tapping the oil pan for the turbo drain>?
http://www.turbowerx.com/Scavenge_Pu...nge_Pumps.html
Old Sep 29, 2010 | 06:16 PM
  #276
spectacle's Avatar
Can you be more specific? What are the sizes of the two restrictors?
  #277
vduber's Avatar
anyone know any tricks to get ahold of mase or anyone from mase engineering? ive sent mulitple pms, emails ive been busy so havent got a chance to call but jesus they must not like money
Old Sep 29, 2010 | 06:24 PM
  #278
Suzuka_Joe's Avatar
I talked with mase about this on monday. If you have a ceramic ball bearing precision 5857, 6262, 6567....... They come with a .034 restrictor in the turbo. Do not remove it, call Mase's shop and youll talk to adam, nick or mase and tell them you need to order the second restrictor they are making. Its .028-.030 and they custom make them for the mase kit. I believe new kits are shipping this way. The 90 degree fitting that the oil feed goes onto the turbo with is the new restrictor. Mase welds them up and drills a hole in them and cost is about $15 for it.
Old Sep 30, 2010 | 03:17 AM
  #279
wait4vtec's Avatar
What about if you have a jb turbo?
Old Sep 30, 2010 | 10:53 AM
  #280
dsddcd's Avatar
Totally different story
Last I heard they were still using a 0.035" Restirctor
