OEM disk and ACT HD pressure plate max power?
Old Nov 29, 2018 | 10:49 PM
  #31
Dethred's Avatar
Originally Posted by F1TwoThousand
That's some QUICK shifting. I havn't seen an S2k shift that quickly actually. From what i've read diffs blow mostly from hard/not hard enough launches for an S2K. To physically shift that quickly i think we'd need a short throw shifter and a quick release master cylinder like this:
Blox Racing S2000 Quick Relase Master Cylinder
I might have to be the guineau pig and try it out the MC mod seems interesting.
​​​​​​Do you think the transmission could handle it much at 275-300wtq? The Viper and s2k have very similar shift characteristics so I'm sure it can be done, I've just never tried it because the ap2 clutch/cylinder slip doesn't make it any more beneficial. Plus the 245 rear tires are 110mm narrower than the Viper's, and the Viper would never hook under 70mph (in that video traction control limited the slip whilst shifting to 2nd at 65mph+).
Old Nov 29, 2018 | 10:57 PM
  #32
s2000Junky's Avatar
The S2000 destroys diffs from regular half ass burn outs where the wheels hop and chatter, eventually flexing the carrier bearing end caps pulling the ring/pinion gear apart, that's the first and most common failure in our diffs. Quick shifting done improperly can break gear teeth in the trans. Less spinning inertia ie light flywheels remove shock load from the drivetrain, which is a good thing, because the rpms drop quicker between shifts and you will naturally find yourself shifting quicker to stay in the powerband anyway. A stock ap2 with its 22lb flywheel requires ridiculously slow shifting in comparison because the rpms just hang in the air, and rushing just engages the cdv and or just compromises smoothness and precision. Its like driving a sowing machine. that said, the s2k trans isnt bullet proof. Ive been through a few of them all due to secondary bearing failures. That can happen stock or boosted, but more so boosted. Really high boost guys in the 350+ trq range seem to blow out second gear first. but I think that's just do to raw trq/twist. The bearing issue over more prolonged abuse. If you drive spiritedly but determined and precise i think the s2k drivtrain overall can last a while at most mid/high boost supercharged set ups, because even at 400whp they are typically only putting down 230-250trq.
Old Nov 30, 2018 | 08:39 AM
  #33
riceball777's Avatar
I blew my first diff from a 1st to second gear shift and that was with a 100% stock car not boosted.
Old Dec 2, 2018 | 09:01 PM
  #34
RolanTHUNDER's Avatar
Originally Posted by riceball777
I blew my first diff from a 1st to second gear shift and that was with a 100% stock not boosted power.
Ouch. Was that while you were running semis and on a drag surface with high bite? Diff fluid you ran up to that point?
LAp1
Jun 17, 2016 05:36 AM
yamaha6611
Mar 25, 2016 05:12 AM
TrueSpaniard1
Apr 5, 2013 11:20 PM
RedSex2k
Feb 16, 2009 04:28 PM
