Official forced induction chat thread
Old Mar 20, 2014 | 06:40 AM
  #541
herecomesboost's Avatar
Congrats!
Old Mar 20, 2014 | 08:43 AM
  #542
s2000Junky's Avatar
Originally Posted by CoolGuy094
Yeah, it will definitely settle down the engine movement... just like a set of aftermarket mounts would. But I would expect it to translate a lot of that absorbed force into the cabin in the form of buzz/vibration (just like aftermarket mounts do).
They're decently cheap, so if you can figure out a mounting method I'd say its worth a try. I sold mine for nearly what I bought it for new, so no skin off my back.
The best way to set those up is to not be so tight that they transmit all that vibration, the job of these is to limit the added motor twist under acceleration, so run it a bit lose so its more or less "floating" when engine is at idle when there is no twist. I’ve had the best luck running them that way. I’ve tried cranking the shit out of them too so they are real tight at idle and all they do it’s transmit all the engine vibration through the chassis because there is no forgiveness at all. The motor needs to move a little or things are going to start cracking/breaking from the vibration, or at the very least annoy the shit out of you.
Old Mar 20, 2014 | 02:35 PM
  #543
cmn's Avatar
cmn
Nice... does that have the 1.6L turbo engine?
Thanks It's not the new turbo engine, but 2-liter NA. 143hp. Surprisingly quick and fun considering the power.
Originally Posted by herecomesboost
Congrats!
Thanks! I think it could serve me well as a daily driver. And it use a lot less fuel than the old 525ix I've had as a winter beater/daily now.
Old Mar 20, 2014 | 05:11 PM
  #544
CoolGuy094's Avatar
Yeah, its very possible I just didn't have it set up properly. Now that I'm back on stock mounts I may just pick one up again to see how it does.
Old Mar 20, 2014 | 05:24 PM
  #545
bottleboy's Avatar
how do you figure out what spring setting you need in your bov
i read its good to keep a serten amount of pressure to counter act turbo lag
Old Mar 23, 2014 | 11:09 AM
  #546
d-bo's Avatar
it just goes by vacuum at idle
Old Mar 23, 2014 | 02:40 PM
  #547
MBHs2k's Avatar
For a 350-400 WHP supercharged s2000, what weight flywheel would be best?
Old Mar 23, 2014 | 06:59 PM
  #548
CoolGuy094's Avatar
AP1 flywheel would be fine IMO.
Old Mar 23, 2014 | 07:09 PM
  #549
bottleboy's Avatar
thanks
Old Mar 24, 2014 | 05:50 AM
  #550
liquid_helix136's Avatar
So for 400-450whp turbo set up, on an 03 F20c with 160k miles, would you be worried about the stock valve springs / guides / seats? I changed the retainers about 10k miles ago, and will be putting in a new short block this week. I haven't had any issues in the head, and I know normally stock would be sufficient, but with the mileage, are these things you would think are worth the hassle of replacing?
