Official forced induction chat thread
Old Apr 23, 2014 | 05:15 AM
  #661
illestrolla's Avatar
Originally Posted by baZurk
I'm I right when I say that the Fullblown radiator and mishimoto radiator are the same?
Yes, you'd be surprised how much of that stuff is re-branded. There is absolutely NO difference.
My "FBM" fans don't even say anything on them
Old Apr 23, 2014 | 05:17 AM
  #662
baZurk's Avatar
Haha I believe mine are the same way. I want to find a fan shroud first to see if that solves my issue. If it doesn't, I will be ordering the two most powerful 12" fans I can find
Old Apr 23, 2014 | 05:18 AM
  #663
RAIN H8R's Avatar
The mishimoto fan shroud is garbage as it blocks the area around the fans. You want to allow the air to flow through the shroud so it can dissipate the heat while at cruising speeds. Usually the only time you need the fans on is at idle or at low traffic jam type speeds where there is not enough air movement to blow through the radiator.
1200 cfm would be enough. I dont know what my fans are, but i know they are two inch thick spal units. One is about 12 or 14 inch with curved blades. The other is 10 or 12 inches with straight blades. I think these are in the 900-1200cfm range
Sent from my SCH-R970 using Tapatalk
Old Apr 23, 2014 | 05:19 AM
  #664
RAIN H8R's Avatar
What exactly is your issue?
Old Apr 23, 2014 | 05:24 AM
  #665
baZurk's Avatar
My car is overheating slightly at speed. It doesn't overheat at idle. I have a fullblown radiator with fans and I use Honda blue coolant. I've bleed my coolant system more times then I can count so there has to be something else causing this.
Old Apr 23, 2014 | 05:32 AM
  #666
lude92_si's Avatar
That's what I have but yet to try them out. Check with Dewey at thmotorsports. Best price I could find man.
Old Apr 23, 2014 | 05:46 AM
  #667
camuman's Avatar
stuff is way cheaper then amsoil. WAY cheaper.
Old Apr 23, 2014 | 07:56 AM
  #668
1SlowSi's Avatar
Originally Posted by AFK-S2K
Originally Posted by 1SlowSi' timestamp='1398251949' post='23125754
[quote name='lude92_si' timestamp='1398213821' post='23125254']
Because of e85 I change everyour 800 miles shell Rotella non synthetic.
Do you like the shell? I was thinking of running the T6 with my setup. S200sx fmw on flex fuel
I'm now a big fan of it. For one, the price point can't be beat and two, I have reviewed countless oil analysis reports with gas and E85 and the Rotella stuff has always been strong with good TN ratings, and other additives and look to be in the same level as Amsoil, brad pen, and other "racing" oils. Eventually I plan on switching to the T6.
Rotella T5 user here. love it. I use it in the S and in my daily ranger.
1SlowSi, is that 800 miles your saying becouse of E85? Care to explain why or send me a link as to why so short of interval changes?
[/quote]
I change it so often for easy/cheap insurance really. 800 miles on my car takes a couple months and its only $20-25 a change. E85 tends to contaminate the fuel and the ethanol will break down the oil faster than regular gasoline. Im sure at 800miles the TN rating for the oil is still usable/acceptable...im just anal like that. Honestly, I used to take it up to 1500-2000 miles but the oil would come out looking thin and with a strong smell of alcohol/ethanol.
The ONLY way to figure out what mileage to change oil would be to run it at a certain mileage, send it in for oil analysis, and see what the TN rating is and what they say in the notes as far as how many miles more you can go.
Old Apr 23, 2014 | 10:48 AM
  #669
RAIN H8R's Avatar
Pm me more info on your setup. Ill try to help you out.
Old Apr 23, 2014 | 11:01 AM
  #670
baZurk's Avatar
PM sent
