Official forced induction chat thread
Old Apr 23, 2014 | 11:39 AM
  #671
spectacle's Avatar
Originally Posted by mirabileboy
have you guys ever had problems with holding boost up top? Just had my car retuned, but it was holding 15psi until around 7k rpm then dropping to 11psi (spring rate in waste-gate). Im running a manual boost controller; so im thinking it could be the waste-gate diaphragm. Any ideas? I ordered a new diaphragm and a 3.7lb spring im going to be adding to the 11.
My car does it and so do a few others I've talked to. Probably has something to do with backpressure opening the gate more than necessary. Or we have a boost leak lol.
You can "fix" it with any normal EBC that lets you ramp up duty by RPM. A manual won't cut it. I went from a 7 psi spring to a 14.5 spring and it did the same thing.
Old Apr 23, 2014 | 06:11 PM
  #672
2004TurboS's Avatar
Originally Posted by baZurk
My car is overheating slightly at speed. It doesn't overheat at idle. I have a fullblown radiator with fans and I use Honda blue coolant. I've bleed my coolant system more times then I can count so there has to be something else causing this.
What are you temps getting up to? I have the same exact fan/rad setup. Also use the same coolant. I am turbo as well. I heard that there rad caps can be crappy but I have not had an issue with the one they sent me.
Old Apr 24, 2014 | 04:32 AM
  #673
baZurk's Avatar
I don't know exact numbers. I never got the chance to get my laptop connected and now my car is up on jackstands for a few weeks. I bought the radiator used and the last guy said that he replaced the cap because he was having an issue.
Old Apr 24, 2014 | 04:52 AM
  #674
camuman's Avatar
Originally Posted by 2004TurboS' timestamp='1398305491' post='23127246
[quote name='baZurk' timestamp='1398259482' post='23125940']
[/quote]
i really hope people know what overheating is though. thats the biggest misconception.
Old Apr 24, 2014 | 05:49 AM
  #675
2004TurboS's Avatar
I heard anything over 215 you should be concerned. I hate when mine gets over 200.
Old Apr 24, 2014 | 05:50 AM
  #676
Redline S2K's Avatar
I asked this earlier too. I need to get fans also. I'm thinking about getting one spal extreme series fan and one slim fan for the ac
Sent from my SM-G900P using Tapatalk
Old Apr 24, 2014 | 06:10 AM
  #677
2004TurboS's Avatar
How would running two 12" spal fans work? Also what is better two pull fans or 2 push fans? Mounted on the front or back of the rad depending on what one.
Old Apr 24, 2014 | 06:30 AM
  #678
baZurk's Avatar
Well my car shouldn't be rising two bars (AP2) over normal operating temp when driving around. It gets hotter if I am doing any "spirited driving". Even at stead speed above 60 it jumps around. I guess I can't really say anything until I get my laptop hooked up.
Old Apr 24, 2014 | 06:38 AM
  #679
camuman's Avatar
do you run stand alone? if so which one, if aem v1, do you use modifry temp driver? reason i ask is i run aem v1 with modifry, and it changes the temp gauge scale. def hook your laptop up asap. the stock gauge doesnt budge from 180-225ish for reference. that is considered normal.
Old Apr 24, 2014 | 06:44 AM
  #680
baZurk's Avatar
AEM v2. The temp/voltage graph has been properly scaled. Unfortunately my car is up on jack stands and I am sending the diff out this weekend to get it built so I wont be able to drive the car for a few weeks.
