Official forced induction chat thread
Old May 23, 2014 | 09:15 AM
  #781
APoner's Avatar
Originally Posted by herecomesboost
Originally Posted by Redline S2K' timestamp='1400765658' post='23171035
How are you guys running the c16 wire for the AEM wideband into the ecu? I t-tapped mine instead of depinning it. Do you thing this would cause an issue with it reading correctly?
I cut the wire at the ECU (left 2-3" of wire from the pin). In answer to your question, I don't think your t-tapped method will affect the functionality in any way.
I did the same. Used a butt connector and heat shrinked the whole connection. I also just pinned the D connector with the supplied pins that AEM brings in the box
Old May 24, 2014 | 10:40 AM
  #782
Chance S2K's Avatar
I'm going to bump this up with a couple of questions, hope you all don't mind
1 - It looks like my 450WHP goal will be quite feasible with the manifold/turbo that I've already purchased. My car will likely have 70-75K miles on it by the time I get around to completing the build and tuning the car. Although I would really like to avoid internal engine work, would it be a good idea to install ACL rod bearings and ARP head studs prior to boosting the car? I don't think I'll ever go above 500WHP, but I want this motor to be as reliable as possible for as long as possible...
2 - I decided I did not need to ask this question... lol
Old May 28, 2014 | 09:25 AM
  #783
omarisramo's Avatar
How do I know if the rear dif went out? I've been hearing a funny thump/clunk noise coming from the rear. It's not always there but still makes noise.
Old May 28, 2014 | 10:03 AM
  #784
KaNgArOo's Avatar
When you drive it and it doesn't move anymore, then you'll know it went out. But i would just change the fluids and if its still driving fine, then you're ok.
Old May 28, 2014 | 10:08 AM
  #785
lude92_si's Avatar
This when you KNOW its blown
Attached Thumbnails Official forced induction chat thread-forumrunner_20140528_140712.png   Official forced induction chat thread-forumrunner_20140528_140750.png
Old May 28, 2014 | 10:12 AM
  #786
omarisramo's Avatar
The rear diff isn't in pieces yet.
Old May 28, 2014 | 10:16 AM
  #787
lude92_si's Avatar
Lol that's a good thing. Change fluid see if that helps. And make sure your axle nuts are tight
Old May 28, 2014 | 10:23 AM
  #788
omarisramo's Avatar
Replaced the fluid back in January/February. Probably have driven less than 500 miles since replaced the fluid. And i'll check the axle nuts when I get back. Thanks. Looking for other possible outcomes.
Old May 28, 2014 | 10:32 AM
  #789
spectacle's Avatar
Holy !!!!!!!!!!
Old May 28, 2014 | 10:50 AM
  #790
S2-Kai's Avatar
Time for a 350z diff setup!
