Official forced induction chat thread
Old May 28, 2014 | 10:25 PM
  #801
lude92_si's Avatar
I have a new full mishimoto setup with dual fans and shroud I will be installing
Old May 28, 2014 | 10:51 PM
  #802
RAIN H8R's Avatar
I would NOT install that.
Old May 28, 2014 | 11:08 PM
  #803
lude92_si's Avatar
Reason? Many run them without issue. Has to be better than the stock unit.
Old May 29, 2014 | 05:00 AM
  #804
CoolGuy094's Avatar
Meh, I have the Mishimoto radiator and some SPAL medium profile fans (13" and 11"). Worked fine last summer and working fine so far this summer. I tried to go with the Mishimoto fan shroud w/ fans, but it wouldn't fit in my setup. The only negative I've seen so far is that I wired them up directly to the OEM wiring and there is a noticeable voltage drop whenever they come on. But my alternator is also 14 years/136k miles old too, so that probably isn't helping.
*Edit - Just go ahead and buy a Spoon radiator cap and toss the Mishimoto one in the trash. Save yourself some time.
Old May 29, 2014 | 05:08 AM
  #805
baZurk's Avatar
The stock radiator itself has a huge design flaw when it comes to coolant flow through it. If you want to upgrade your cooling system, it is better to find a superior design (dual pass) then to just get a thicker, aluminum radiator with the same basic design as stock
Old May 29, 2014 | 07:08 AM
  #806
lude92_si's Avatar
Well already have the brand new mishimoto so its going in.
Old May 29, 2014 | 07:28 AM
  #807
baZurk's Avatar
If you have a fan shroud you should be ok. My car seems to be fine unless ambient temps are over 80F
Old May 29, 2014 | 07:52 AM
  #808
lude92_si's Avatar
Yeah and maybe those two 10" fans will help. We will see
Old May 29, 2014 | 09:03 AM
  #809
illestrolla's Avatar
This.
The dual pass is where it's at. Can't find the thread right at the moment though :/
Old May 29, 2014 | 09:09 AM
  #810
baZurk's Avatar
Originally Posted by illestrolla
This.
https://www.s2ki.com/s2000/topic/940...or-for-racing/
