Official forced induction chat thread
Old May 22, 2014 | 01:07 PM
  #771
lude92_si's Avatar
Yeah it went in and will snug up tight. I hand tightened it went to take it out had to use a wrench. I think it will hold. Just wanted to make sure the location was ok
Old May 22, 2014 | 02:52 PM
  #772
baZurk's Avatar
I plan on tapping my compressor housing on the elbow I added or just on to the intercooler pipe. I'm sure it will be fine.
Old May 22, 2014 | 03:22 PM
  #773
s2klariat's Avatar
Originally Posted by lude92_si
Ok well I really didn't want to drill into my new Turbo so I tapped the ic pipe just off the Turbo.
Will this work fine to run my vacuum lines for my wastegate and boost solenoid?
That'll be just fine.
Old May 22, 2014 | 03:24 PM
  #774
s2klariat's Avatar
Originally Posted by 2004TurboS
Apply the heat wrap wet or dry? And has anyone used vht flameproof paint for there turbo manifold?
I applied dry. Wear rubber gloves and long sleeves, dont learn the hard way like me. That stuff will eat you up!
Old May 22, 2014 | 04:28 PM
  #775
lude92_si's Avatar
I did mine wet, went on fine.
Old May 22, 2014 | 04:31 PM
  #776
lude92_si's Avatar
Yeah almost tapped my elbow too Matt, then said hell ic pipe is chespuand easier to replace if it doesn't work. My ic pipe is pretty heavy not cheap eBay stuff.
Old May 22, 2014 | 04:47 PM
  #777
Hicktown s2k's Avatar
Is it worth it to go with E85 on a turbo build? What are the parts needed to go E85? will normal 1000cc injectors work? Thanks
Old May 22, 2014 | 08:33 PM
  #778
Redline S2K's Avatar
Here is another solution if your doesn't work or for anyone that doesn't want to drill their turbo.
http://www.atpturbo.com/mm5/merchant...egory_Code=BCS
Old May 23, 2014 | 08:17 AM
  #779
herecomesboost's Avatar
Originally Posted by Redline S2K
How are you guys running the c16 wire for the AEM wideband into the ecu? I t-tapped mine instead of depinning it. Do you thing this would cause an issue with it reading correctly?
I cut the wire at the ECU (left 2-3" of wire from the pin). In answer to your question, I don't think your t-tapped method will affect the functionality in any way.
Old May 23, 2014 | 08:29 AM
  #780
That's exactly what I plan on doing today. Jeff wants me to try that before he makes any changes to the base tune he sent me. I don't feel it could cause a problem but who knows. Maybe the wire is causing extra resistance making the sensor read off. Simple thing to change just to eliminate it as a potential problem.
