Official forced induction chat thread
Old Dec 11, 2013 | 08:39 AM
  #81
Suzuka_Joe's Avatar
Anybody with an ems v1 have a serial gauge cal file they can send me so it will display aft, boost, water temp.. oil pressure will be a plus. I'm sure I can set it up but a start would be nice
also, I have ems v1 and i'm wanting to switch to v2. how much of the tune file from my v1 will work in v2? can I at least drive it to the tuner on the v2 with the v1 map? curious how much of a retune I'd need
Thanks
Old Dec 11, 2013 | 10:00 AM
  #82
KaNgArOo's Avatar
I know that AEM V2 has an option for flex fuel, But will the new flex fuel option that SOS is working on an AEM V1???
Old Dec 11, 2013 | 10:05 AM
  #83
baZurk's Avatar
The v1 cannot run flex fuel. What SOS is marketing is a flex fuel setup that is compatible with any tuning solution (EMS) that has the necessary software to operate.
Old Dec 11, 2013 | 11:35 AM
  #84
Suzuka_Joe's Avatar
time for us both to upgrade to a v2
Are my id1000's sufficient enough to make 400whp on e85 with a better fuel pump? then i can fill up with either 91 or e85 and the ems will automatically make adjustments??
Old Dec 11, 2013 | 11:41 AM
  #85
S2-Kai's Avatar
Yes, n yes Joe.
Old Dec 11, 2013 | 11:50 AM
  #86
KaNgArOo's Avatar
Joe! For sure! That flex fuel sounds tempting, but i don't think i want to drop another $1000 on a new EMS.
And I thought i bought the ID1000 from you already. You must have had 2 sets?
I think ID1000 can handle up to 500whp with a good fuel pump set-up on E85. Correct me if i'm wrong, but that;s what i'm shooting for.
Old Dec 11, 2013 | 12:02 PM
  #87
Suzuka_Joe's Avatar
you did. I came out of my mild panic attack and decided to put the turbo kit back on so I bought a new set from moddiction. There were a few short cuts I had taken the last time I installed the kit and i'm fixing all those little issues now.
secondly- What is the part number for the o2 sensor that works with AEM but is alot cheaper?? I can't remember and I need to order one. I believe bosch makes it
*edit. here it is AEM Bosch replacement sensor
Old Dec 11, 2013 | 12:17 PM
  #88
jordannn93's Avatar
How much horsepower/psi does a single Walbro 255 max out at on pump gas ?
Old Dec 11, 2013 | 12:42 PM
  #89
Suzuka_Joe's Avatar
Originally Posted by jordannn93
How much horsepower/psi does a single Walbro 255 max out at ?
i made 423 @13psi with id1000 injectors and i think there was room left. i'd guess around 475-500 with id1000's
Old Dec 11, 2013 | 01:56 PM
  #90
Rugby_Guy's Avatar
If you max it out, do the hardwire/relay mod to get some more juice to it
