Official forced induction chat thread
i've heard the serial gauge is a total bitch to get functional. is that true or did I get bad info? i'd like to buy one and program it to display boost, engine temp, oil pressure, voltage, and AFR. I might run two of them so one displays boost and one displays AFR. I already have a double gauge a pillar mount
Total bitch? No. Pita? Yes. But you can always have someone email there gauge calc file and just upload that. Then the only wild card is the map sensor. As each calc I think is based on a certain map sensor. It's been years since I did mine. So I'm going off that lol. What map sensor are you running?
E85 walbro 400 install. Can I repin the stock connector that sits under the hanger with the flying leads that come with the e85 pump kit? I'm going to do the relay mod too, and not sure if the stock connector will be okay if TA repinned with larger gauge wire. Don't want to drill in the hanger lid if I don't absolutely need to
Sent from my iPhone using Tapatalk
Those things are tricky!
