THE OFFICIAL: WATER/METHANOL INJECTION Thread
Old Feb 6, 2011 | 12:00 PM
  #131
siadam's Avatar
I was going to make a thread about this, and I still might.
I was told to use SLX from Home Depot, it's in the paint department. It's basically denatured alcohol.
It's ~15.xx / gallon.
I'm not sure if I want to go 50/50 again, or go something else, 75/25.
Old Feb 6, 2011 | 12:10 PM
  #132
camuman's Avatar
I paid 35 for a 5 gallon jug of m1. Is slx better?
Old Feb 6, 2011 | 08:27 PM
  #133
s2000Junky's Avatar
Home Depot has Denatured Alcohol in the paint section for $15 a gal. Whats the difference between this and SLX?
Old Feb 7, 2011 | 04:11 AM
  #134
JoeyBalls's Avatar
Im lazy so I do 8 Bottles of HEET with 1 Gallon of PEAK -20F
70/30 Mix Meth to water. Alsi check this out, really cool calculator for whatever mix you want
Download the 2nd Excel File
http://www.eteamz.com/bcblues/handouts/ind...4667041#1588965.
Also, I plan on running a few gallons of Xylene per tank this summer for 100 Octane. lil extra detonation suppresion, here is another great link where you can play around with mixtures to get a desired Octane level
http://www.easyperformance.com/Tech_Info/O...d_Frameset.html
Old Feb 7, 2011 | 05:15 AM
  #135
siadam's Avatar
Thats exactly what this stuff costs. To be honest, I do not know the difference.
It's what the guys @ coolingmist told me to run.
I said I use summitracing's boostjuice, and his response was ewwwww. I asked why, do you sell something, he said no. Then he told me about the SLX.
Old Feb 7, 2011 | 08:20 AM
  #136
s2000Junky's Avatar
Ewww huh
Wonder what he would say about me and Joeyballs concoction
Old Feb 15, 2011 | 06:43 AM
  #137
purekoryo's Avatar
how much boost and timing up top were you guys able to gain with water meth injection? on a log manifold and gt30 sized turbo and up with STOCK motor and headgasket? I installed a coolingmist CMGS kit recently and currently boosting around 14.5 psi, with timing ramping up to 12.5-13 degrees up top. I would think i should be able to increase the timing some more along with boosting to about 17 psi? btw, i have a mase kit with electronic cutout and 5857 BB precision turbo.
i also did notice my knock volts dropped from 2.1 V being the max to now 1.5V.
Old Feb 25, 2011 | 04:43 AM
  #138
ap1tuner's Avatar
I just figured id throw this info out since there is a lot of talk about going with higher mixtures of meth/water.... after reading all the print that came with coolingmists's injection kit (just the standard 1.5 gal trunk kit) I noticed it mentioned to never go past a 50/50 mix bc the higher concentration of meth will eat thru all the gaskets and cause the system to fail.
Does anyone have any more info on this bc if I can safely run my kit on 75/25 then I want to.... but I don't want to fubar everything else.
Old Feb 25, 2011 | 09:09 AM
  #139
siadam's Avatar
I didn't see that and don't believe it to be true.
The only thing I saw, and I have to double check, was the methanol to water mixture to either not exceed 50/50 or 70/30 due to damaging the flow sensor.
Old Feb 25, 2011 | 09:26 AM
  #140
ap1tuner's Avatar
I think I'm gonna give coolingmist a call today and get their take on it to be safe. I really wanna get a higher concentration of meth than 50/50 but don't want to ruin my setup.
