Post Your Dyno #'s And Mods!
Old Aug 25, 2008 | 05:25 PM
  #411
passmans2kny's Avatar
Originally Posted by TJTURBO,Aug 15 2008, 05:35 PM
was this made with the 3mm headgasket? what octane?
yes 3mm head hasket with arp studs, 93 octane pump gas
Old Aug 26, 2008 | 04:44 AM
  #412
kutsujula's Avatar
Full-Race kit.
Old Aug 26, 2008 | 12:13 PM
  #413
Sarek's Avatar
Originally Posted by kutsujula,Aug 26 2008, 04:44 AM
Full-Race kit.
Nice work Jeff!
Old Sep 13, 2008 | 10:02 PM
  #414
gt30r's Avatar
tuned @ UMS Tuning
the clutch (exedy twin) started slipping @ higher boost levels
pump gas was 16 psi and race was set @ 23 psi
Re-tune after clutch and fmic are replaced
Old Sep 14, 2008 | 08:51 PM
  #415
Soul Coughing's Avatar
i just got a full-race manifold, and kept everything the same from my old ultimate racing kit.
This is full-race manifold, 3inch DP, 3inch single, and 750cc RC injectors and a 60-1 Hi-Fi
Low Boost 11psi 425whp 290ft/lbs, high boost 18psi dropping to 16 psi at redline 475whp 365ft/lbs (DynaPack). On a mustang dyno with high humidity and 90+ weather it was 460whp and 340ft/lbs on high boost!
Old Sep 15, 2008 | 04:07 AM
  #416
JDM_EM1's Avatar
so the full-race manifold bolted up to UR racing dp no problem?
Old Sep 15, 2008 | 06:34 AM
  #417
i had made my own DP, but it fit. I did have to move the vband flange around on the TP so it would line up perfectly. I made 415-420whp at 18psi with the old manifold, i now make 425whp at 11psi! Crazy what a well designed manifold can do for your power!
Old Sep 15, 2008 | 06:49 AM
  #418
c_me_go's Avatar
Its strange that kutsujula made less TQ then passmans2kny... and they have the same kit.. is it because one was useing a smaller turbo?
Old Sep 15, 2008 | 09:20 AM
  #419
kutsujula's Avatar
the compression is different and again not to take away from passman but different dyno's.
Old Sep 15, 2008 | 09:59 AM
  #420
i was tuned at jeff evans (where Passman was tuned) and made 475whp and 365ft/lbs of torque. One week later i went to a Mustang Dyno and made 460whp and 340ft/lbs of torque, so the difference between the two isn't THAT drastic.
