Post Your Dyno #'s And Mods!
Old Aug 14, 2008 | 10:11 AM
  #391
camuman's Avatar
Originally Posted by PatS4P,Aug 13 2008, 11:43 PM
Oh, and AFR's are at 12.0 at full boost, not a hint of knock
where was that reading taken at? tail pipe sniffer or from stand alone logging?
Old Aug 14, 2008 | 10:53 AM
  #392
PatS4P's Avatar
Banned
Originally Posted by Spoolin,Aug 14 2008, 08:53 AM
What turbo are you using that only netted you 10 whp on a 7 psi increase? That's horrible and it must be way out of it's efficiency range.
2-1/2" DP opening to 3". To restrictive getting to much back pressure up top.
Old Aug 14, 2008 | 10:54 AM
  #393
PatS4P's Avatar
Banned
Sniffer at the TP. Also agreed w/ data logging on O2.
Old Aug 14, 2008 | 10:56 AM
  #394
PatS4P's Avatar
Banned
Originally Posted by GDM S2K,Aug 14 2008, 06:08 AM
lil leaner than most would like ide say..... but that explains why you made such high numbers
That's one of the points of the meth/WI you can run leaner without det. If I ran 75/25 I could be around 12.5 AFR with no problems.
Old Aug 14, 2008 | 11:00 AM
  #395
GDM S2K's Avatar
wouldnt meth let you run more timing rather than less fuel?
Old Aug 14, 2008 | 11:51 AM
  #396
TRBOKEV's Avatar
It allows you to do both.
Old Aug 14, 2008 | 01:05 PM
  #397
passmans2kny's Avatar
535 hp 400 ft-lbs, check sig for mods
Old Aug 14, 2008 | 01:45 PM
  #398
mys2k3's Avatar
Nice #'s How much boost? Pump gas?
Old Aug 14, 2008 | 06:00 PM
  #399
Opposite_Lock's Avatar
Originally Posted by TRBOKEV,Aug 14 2008, 01:06 PM
Ditch the exhaust and cat and this would be close to 400 if not over.
Yeah, we decided to go the capped redline because I'm still on stock compression.
The first run was 370rwhp at 15psi 9K RPM. I'm sure with a 3" single and TP, it would be closer to 385 or so. I need to run stock cats for a few events I'm doing right now, to keep in my class. Eventually, I'll try to maximize power though.
Old Aug 14, 2008 | 06:12 PM
  #400
PatS4P's Avatar
Banned
I was looking for that beast at tech day, nextime or or I'll take the ferry across to see it.
