precision 5857 .82 ar
Old Jun 30, 2010 | 01:10 PM
rsmatti's Avatar
Default precision 5857 .82 ar
hey guys i have a precision 5857 jb with a .82 hot side its also a 4 bolt turbo hot side.. is anyone running p fab.. i know there log manifold fits no problem, but does there downpipe fit???
Old Jun 30, 2010 | 01:25 PM
Suzuka_Joe's Avatar
i think their down pipe is V band only. you'll need a 4 bolt to v band adaptor. check out atp turbo for that
Old Jun 30, 2010 | 01:58 PM
Ek_Jak's Avatar
im actually running the same setup as you right now. i have a precision journal bearing 5857 billet turbo with the pfab equal length manifold and 3 inch dowpipe that has a 4 bolt on it. i have a problem right now tryin to bolt my third bolt from the downpipe to the turbo. its a way stupid design but a word of advice is to get the vband setup.. much more easier to install.
Old Jun 30, 2010 | 02:18 PM
rsmatti's Avatar
if i get a 4 bolt v band adapter will the downpipe still fit im using the log manifold
Old Jun 30, 2010 | 02:29 PM
Ek_Jak's Avatar
the adapter will push the downpipe farther back so it might hit the frame.. i guess you just got to check and see.. if it does, you might have to have the downpipe cut and re-weld the vband flange..
Old Jun 30, 2010 | 02:38 PM
Suzuka_Joe's Avatar
true, there isn't alot of clearance with a pfab dp
Old Jun 30, 2010 | 02:53 PM
rsmatti's Avatar
so wat do you guys this should i order the 4 bolt downpipe or the vband one??
Old Jun 30, 2010 | 04:32 PM
Revenge's Avatar
Well, just order the flange that will fit your turbo. I thought you had a v band and needed to make it fit a 4 bolt.
Old Jun 30, 2010 | 04:37 PM
Suzuka_Joe's Avatar
if you have a 4 bolt turbo and they make a 4 bolt down pipe thats an easy answer
Old Jun 30, 2010 | 08:05 PM
rsmatti's Avatar
no its a 4 bolt turbo and im pretty shure they can make a 4 bolt to order. ill let you guys know how it goes cross your fingers i want this build done already.
detoxclinic
Apr 3, 2014 10:54 PM
jtins2k
Dec 16, 2011 12:00 PM
H4RD ON
Feb 22, 2011 02:49 PM
01BBS2K
Aug 11, 2009 10:50 AM
ChefJ
Jun 20, 2007 06:08 PM
