PTUNING S2000 Turbo System (Pics, Dyno, Pricing)
Originally Posted by miguel329' timestamp='1360351599' post='22324144
make sure you guys msg mrc for all your ptuning needs.... i msg andrew but he no longer works at ptuning.....thanks mrc saw you took care of my order.
MrC
Sent from my SPH-L710 using Tapatalk 2
Can this resonator fit anywhere into the PTuning's dual exhaust?
Ultra Quiet Resonator, 3" inlet/oulet:
http://vibrantperformance.com/catalo...products_id=47
I'd like to quiet it down a bit at constant highway speeds.
Mrc
Mrc
I've even seen someone on here post pictures of two of them in series on his S2000.
I am getting boost creep to the point that it will hit boost cut (16.2 psi) every time in this cooler weather that we have been having. During the summer time I don't have this issue. Boost is set to 15 psi in KPro.
I have the PTuning kit, KPro, GTX 3076R turbo with recirculated dump.
PTuning tuned.
I tried installing the 2.25" Boost regulating disc, but it didn't help.
I think that me having the recirculated dump vs open dump may be the issue.
Does anyone with my setup have this issue?
Any ideas PTuning?
Thanks
PTuning tuned.
Any ideas PTuning?
Thanks
I had this issue when I first got the car. Only 6th gear did it.took it back to them and they messed with my ems a bit and helped the issue but didn't solve it. I think its due to the placement of the wastegate that's causing it.. not sure. maybe with this bump they'll chime in.
PTuning tuned.
Any ideas PTuning?
Thanks
PTuning tuned.
Any ideas PTuning?
Thanks
MrC
