Quick question when installing upgrades
Old Aug 3, 2014 | 05:54 PM
TheMuffinMan's Avatar
Default Quick question when installing upgrades
I've been stock piling a bunch of parts and am finally getting around to installing them. I know I'm going to need a tune after they're installed, but wanted to know what I can get away with installing prior to the tune for the drive over?
I currently have the SoS Stage 2 kit on the stock pulley, and am tuned on the AEM EMS2.
Here's a list of stuff I've got piled up:
- J's Racing Header
- Ballade Sports 70mm throttle body
- Stock IM will be bored out shortly to 69mm
- ID1000 injectors (upgrade from RC650)
- NGK 8's
- 3.2" SoS Pulley
What can I safely install without risking damage to the car and still drive it to my tuner (~1 hour away)? The car isn't tuned too aggressively so I was thinking I could install all of it and then limp it over for the tune.
Any suggestions?
Old Aug 3, 2014 | 09:51 PM
CoolGuy094's Avatar
You'll need to update the flow and dead time settings for the injectors in order to get it to run well enough to drive over there. Everything else should be OK as long as you drive it like a grandma and watch your AFR gauge like a hawk on the way.
Old Aug 4, 2014 | 12:44 AM
leoxle's Avatar
What Coolguy said. Also, Post up the numbers after a retune! I am curious as to what you'll make cause i'll be SOS supercharged very soon.
Old Aug 4, 2014 | 11:43 AM
Appreciate it, that's what I figured.
I've got my AEM Serial hooked up so I can definitely keep an eye on things - should I just hold off on installing the injectors?
Old Aug 4, 2014 | 12:38 PM
CoolGuy094's Avatar
That's another option. I've swapped injectors quite a few times now and it doesn't take more than 10 minutes or so to do it. Might just be easier to do it on the dyno and have your tuner worry about those settings.
Old Aug 5, 2014 | 05:26 PM
staylor725's Avatar
That's what I did drove the car to the tuner swapped injectors and map sensor in the parking lot then let the tuner take over from their. Make sure you show up early to let the car cool down some before trying to swap injectors good luck.
Old Aug 5, 2014 | 05:59 PM
sohc_mshue's Avatar
- J's Racing Header
- NGK 8's
- 3.2" SoS Pulley
Any suggestions?
Let me know when its ready and I'll send you over a map
Old Aug 8, 2014 | 06:20 AM
- J's Racing Header
- NGK 8's
- 3.2" SoS Pulley
Any suggestions?
Lol, guess I probably could have just asked you!
Ludeboye1
May 25, 2012 04:00 AM
Kris AP1 S/C
Nov 4, 2010 07:07 AM
CKit
Feb 21, 2009 04:25 AM
S2KKC
May 13, 2008 10:53 AM
crockey
Jun 23, 2006 12:42 PM
