Re building engine (need help)
Old Nov 17, 2014 | 05:38 AM
Juniorbr19's Avatar
Default Re building engine (need help)
I'm rebuilding my entire engine, and I'm concerned to use the same old parts when I put the engine back together. Do you know or have you heard of adding lots of boost and the oil pump giving up? or not pumping with the same intensity as a new pump, since the old one has over 100k miles on it already? I'm of corse changing the water pump since it's cheap, but didn't want to have to change the oil unless I really needed to.
Thanks in advance!
Old Nov 17, 2014 | 06:09 AM
Chance S2K's Avatar
I'd definitely recommend dropping in a new oil pump while you have the car apart... Better safe than sorry; if you're rebuilding your engine you may as well do it right and cover all your bases.
Old Nov 17, 2014 | 08:41 AM
staylor725's Avatar
I would replace it
Floppy
Jun 9, 2015 12:23 PM
riceball777
Dec 2, 2013 09:54 AM
Webfoot
Oct 13, 2009 05:10 AM
pinoyk20
Aug 19, 2007 09:18 AM
OC_
Oct 12, 2003 09:01 PM
