Re-tune necessary?
The tune should be fairly close. You should be fine to drive it around until you get it tuned as long as you drive the car easy. Likely the tune will just need some small tweaking. You are not going to hurt anything just cruising around driving out of boost.
Hey thanks for all your guys help, turns out I can't even use the new manifold because it's a little bigger so if it's not mounted to the studs I can't get it in the right position to bolt the turbo to it. And if it is mounted on the studs then I can't reach the bolts.
