Rotrex C38 Kraftwerks log
Originally Posted by dduaime
Engine rpm
Stock pulley on 2.2L(100mm/70mm), engine max speed must be 8400rpm engine = 12000rpm blower.
Stock pulley on 2.0L(100mm/80mm), engine max speed must be 9600rpm engine = 12000rpm blower.
If the ratio was 1:1, you would be right.
The calculation is very simple: Crank / Blower x engine rpm
100 / 70 x 8400 = 12000
I begin to understand when YOU dare to say that there is a lot of misinformation on this site ...
Engine rpm
Quote
Opened up the KW kit boxes. Crank pulley is 40 teeth/100mm and blower pulley is 28 teeth/70mm. 8300 rpm red line and 1.428 ratio through the pulleys gives 11,850 rpm on the C38-81 input shaft. Rotrex site says 12,000 rpm is peak input shaft speed.
I was stating that the 150rpm is NOT engine rpm it IS the Rotrex's rpm. The difference between 11,850 and 12,000 is 150. This is what I was stating.
If you use the C38's 7.5:1 ratio and calculate based on the reported "8300rpm" in that quote these are the numbers:
8300(rpm) x7.5(C38 gearbox ratio) x100 (Kraftwerks crank pulley diameter)/ 70 (supercharger drive pulley for 2.2liter)=88928.5714 (C38 blower rpm at 8300 engine rpm). Rotrex states 90,000 MAX rpm.
Yor calculations are NOT wrong. Perhaps I could have been more clear about that part of my reply. (my bad on that one)
The quote that 150rpm is engine rpm IS incorrect.
You are right this time.
There are several way to express the same thing.
The fact remains:
Stock pulley on 2.2L(100mm/70mm), engine max speed must be 8400rpm engine = 12000rpm rotrex input shaft.
Stock pulley on 2.0L(100mm/80mm), engine max speed must be 9600rpm engine = 12000rpm rotrex input shaft.
The fact remains:
The fact remains:
Sorry for the misunderstanding.
Daniel, we apologize you are unhappy with the supercharger kit and our service. You contacted us via Facebook and we had asked to email us at support@kraftwerksusa.com so a tech advisor could help you, however that email seems to have never been sent, which means we never had the chance to make this right. You've been messaged again via Facebook with information about the injectors, PLEASE email us this time. Below shows what parts we'd like to get in your hands.
Better communication.
Thanks CJ Weidl
Originally Posted by KraftWerks' timestamp='1395791921' post='23081120
[quote name='cvjoint' timestamp='1395740923' post='23079827']
[quote name='KraftWerks' timestamp='1395677630' post='23078293']We've been very transparent in the process of helping the few customers that have had issues. We made "cvjoint" numerous offers and he refused all of them and proceeded to contact his credit card company, rather than getting a refund from the dealer he purchased it from. Again, we all enjoy cars here at Kraftwerks, so we recognize how much of "bummer" it can be when you don't have everything you need.
[/quote]
When Amazon ships something incorrectly they issue an RMA in a day. I gave you and the distributor over a week to figure out the return logistics and then contracted my credit card when it was clear you had no intentions on making good on your promise. I made my intentions clear and you still didn't budge.
[/quote]
Actually just to clarify, we've worked with you every step of the way trying to resolve the issue and trying to give you a number of solutions. As soon as we were notified that you had an issue we contacted KW and began working on a solution for you. You weren't satisfied with anything that was proposed and seemed to change your mind from day to day. I'm sorry you had incorrect parts. Normally, customers will allow us to get the correct part but you were adamant about getting a return on parts you already installed. Thus, we had to contact KW to get approval, an RMA, and a call tag so that you could get the parts returned and we could refund you. I'm not sure where we fell short as we worked to help you out once we were actually notified.
Our pulley combination makes sense:
Kraftwerks: 70mm upper - 110mm lower - 8,400rpm
Has anyone done the calculation on the other kit?
Competitors kit: 90mm upper - 135mm lower - Claimed 8,600 redline at 18psi (?) (we sense some warranty voiding action happening)
Who has the competitors "Race" kit installed, we'd be more than happy to dyno it here at our facility, message, call or email us if you have one. Heck, maybe we can just turn it into a little meet here at our facility!
Originally Posted by s2000Junky' timestamp='1395887189' post='23083248
Regardless, if its 150-200-500rpm, it isn't crap when you consider how much boost/cfm that equates to. Its basically maxed out of the box. So what ever people are seeing on the dyno, that should be your expectation.
All your effectively saying is the result of running a smaller pulley for more power, is its just shifting the higher boost curve further down in the rpm range, which is counter productive to a motor that is most efficient in the upper range. As I said previously, if you had a stroker motor that could only safely rev to say 7500rpm for example anyway, then sure it would make sense to max the blower out at that lower rev limit because that’s where the motor craps out. Capping off a motor prematurely before 8500-9000rpm where our motor makes its peak power, for the sake of the blowers rev limit, doesn’t work, nor can you claim the blower has plenty of headroom to grow. I don’t mean to beat you up, but the story isnt jiving. Am I missing something here? Please clarify if so....
Originally Posted by cvjoint' timestamp='1395810908' post='23081548
[quote name='KraftWerks' timestamp='1395791921' post='23081120']
[/quote]
[/quote]
[/quote]
I think his issue is not with you, but with Kraftwerks, for shipping an incomplete product. In other words, it was not delivered to him as advertised. You're just caught in the middle because you facilitated the transaction, even if you are not at fault for the missing/wrong components.
They have similarly bad reviews on the Miata and FRS forums; someone needs to get it together at KW.
