SC...will it fit?
Old Nov 27, 2005 | 11:09 PM
Erick S's Avatar
Default SC...will it fit?
In the process of purchasing a SC, and have a very important question. The SC is for an AP2 and I have an AP1. Will this fit? What modifcations need to take place if any? What concerns should I have, if any?? Please, I need info.
Happy Holidays. This is my Christmas gift...to me!!
Thanks!
Erick
Old Nov 28, 2005 | 05:13 AM
Sideways's Avatar
There are a few minor differences.
The pulley for the AP2 is 4-1/2 inches and the AP1 is 5 inches. This will boost about 3 lbs more than you want so you should change it. There are lots of 5 inch pulleys around used. New they are only $100.
That was the easy part. The electronics are much different and I am not versed in the details.
Old Nov 28, 2005 | 07:01 AM
kinetica's Avatar
What electronics are different? Would a stand alone EMS be able to take of this? Or just a new black box from Vortech?
Old Nov 28, 2005 | 09:10 AM
Erick S's Avatar
Thanks for the response, is anyone reading knowledgable about the electronics involved?
Erick
Old Nov 28, 2005 | 10:20 AM
kinetica's Avatar
I called Vortech and this is what is needed to make the AP2 kit work with an AP1:
Time control box either reprogrammed locally of purchased new from Vortech for $958.
Aftercooler discharge assembly changed for $500.
Pulley/belt changed (or kept if wanted extra boost) for around $200
A Calibration disc to change the ratio to 4:1 on the FMU??
Old Nov 28, 2005 | 05:26 PM
Slows2k's Avatar
Other than the pulley size change, the 04-05 kit uses an Aux injector mounted in the aftercooler, as well as a different timing/fuel controller.
If you get the 04-05 kit, you'll need a 5" pulley, and the timing control only box, intstead of timing and injector controller. Pick up a 10:1 kit for the FMU, and thats it.
You can get the timing box, FMU, as well as 5" pulley all used from those who upped the boost and switched to an EMS.
Old Nov 29, 2005 | 02:58 PM
Erick S's Avatar
Thank you for the informative responses...very much appreciated.
Happy Holidays..
Erick
sarge1
Dec 18, 2016 08:59 AM
tylers2000
Dec 18, 2016 08:49 AM
Moddiction
Nov 22, 2009 06:51 PM
wing
May 30, 2009 07:12 PM
08s2000CRbackinblack
Oct 12, 2008 08:42 PM
