ScienceofSpeed Supercharger System Updates
Originally Posted by Druz,Aug 19 2009, 02:08 AM
Hopefully I can finish installation tonight after work.
Still no EMS yet which is very annoying.
plug n play baby!!!!!
Originally Posted by MasterForce,Aug 19 2009, 02:10 PM
sucks!! i like the Hondata reflash
plug n play baby!!!!!Question to you guys. How close does your crank shaft pulley with the supercharger piggy back pulley come from the steering rack? I do not have much room between the edge of the pulley and part of the rack. I don't want it to make contact if the engine jumps.
Originally Posted by TelosHedge,Aug 14 2009, 07:39 PM
semen is good lubrication for the sos blower.
its called the 1220SL for a reason - semenically lubricated.
uhhhh... 'homey' is just about married, and is too old to be fluent in urban language.
on an intelligent note....
has anybody attempted to use the titanium CT shock tower bar with this system? i got mine to fit but the clearances are a little close to the aftercooler - looks like it'll smack the bar easily if the motor moves.
anybody got any tricks?
Finished everything off today. I went and left the supercharger belt off and kept the stock injectors and ECU hooked up. This way I will drive over to InlinePro tomorrow morning and get them to tune it.
No real complications. Had some mix up of some vacuum lines. Also, I see oil around the VTEC solenoid and can't tell if it's leaking or if its oil that didn't get cleaned up after remounting the thing. I'll keep an eye on it. Also, I'm not sure if I need to bleed the coolant system after hacking the hose up. I topped it all off after I was done but not sure if air is in the lines.
Here is my finished picture...it looks like the others but I figured I'd throw mine out there:
and the upgraded heat exchanger:
Total install time was about 11 hours. I wasn't rushing through it by any means. I'll comment on it's performance once it's finished being tuned.
