Sent out my block to be made Bulletproof
Old 11-07-2005, 04:43 AM
jbotstein1's Avatar
Default Sent out my block to be made Bulletproof
Last Monday I sent my short block to Earl Laskey in California. I am getting it Benson sleeved, CP 9:1 pistons at stock bore, pauter rods, and everything else he'll do to make it sweet. He said about 6-8 weeks. I should be able to run up to 40 psi, but I only have the UR gen II kit, so I dont think I'll be able to get that high till I upgrade things(mani, turbo, downpipe, etc.) What do you guys suggest as far as the upgrades I will need excluding drivetrain, to make the most boost?
Old 11-07-2005, 09:34 AM
stitos2k's Avatar
You may want to get the crank shaft balanced while your at it, and have the valve springs adjusted. That's about all I got besides maybe a better oil pump?
Oh ya, make sure you have the update oil banjo bolts. You have a 2002 by your sig so I doubt you need them. I don't remember what year they started using the new ones.
Old 11-07-2005, 09:38 AM
Asura's Avatar
What oil pump did you upgrade to?
The upgrade oil banjo bolts started mid way through 2002. There is an FAQ and you can check by VIN. The easier way would be to have the engine builder look and see if there are four holes or two.
Old 11-07-2005, 03:05 PM
Silver S2k4's Avatar
how much is the block costing you?
Godzhand
10-21-2013 05:59 AM
bobbyrandolph440
12-01-2012 02:54 AM
dibi
08-07-2010 05:22 AM
SpoolinU
12-08-2009 11:29 AM
herecomesboost
06-08-2006 08:05 PM
Quick Reply: Sent out my block to be made Bulletproof
