Suggestions
Hello folks
I am getting my car back with a built sleeved lower compression engine,9.1 to be exact.
Will i be fine running the previous map to break in the engine and then get it tuned ?
THANK you for the help
As far as just putting around though I agree with umair: If the fuel setup is still the same then the old map should work fine for the lower end, just monitor your AFR and make sure you're not leaning out.
Great. Should I lower my boost controller to prevent boost? You do have to rev it up to 4K rpm or so as part of the break in. So overall I should be safe as long as i dont beat on it?
Thanks for the great answers
If your AFR still looks good I may even say just turn the boost all the way down so you can rev the engine out as far as the break in requires, but I'd definitely consult a tuner/builder first before going to ohard into the rev range with an untuned new engine.
Just to be thorough, I'd use break-in oil as well. Driven oil from Joe Gibbs Racing is good stuff.
http://www.drivenracingoil.com/dro/p...embly-oilshtml
