Suggestions
Old Dec 16, 2015 | 08:27 PM
geekyjerry's Avatar
Default Suggestions
Hello folks
I am getting my car back with a built sleeved lower compression engine,9.1 to be exact.
Will i be fine running the previous map to break in the engine and then get it tuned ?
THANK you for the help
Old Dec 17, 2015 | 12:57 AM
umair's Avatar
As long as you have the same injectors and your air fuel isn't out of range you will be ok. Just dont hit boost.
Old Dec 17, 2015 | 05:42 AM
Chance S2K's Avatar
I think you're actually supposed to start revving the motor up a bit at some point during the break in (after several hundred miles). Not sure if that's really important or needs to be done prior to the dyno.
As far as just putting around though I agree with umair: If the fuel setup is still the same then the old map should work fine for the lower end, just monitor your AFR and make sure you're not leaning out.
Old Dec 17, 2015 | 08:04 AM
geekyjerry's Avatar
Great. Should I lower my boost controller to prevent boost? You do have to rev it up to 4K rpm or so as part of the break in. So overall I should be safe as long as i dont beat on it?
Thanks for the great answers
Old Dec 17, 2015 | 09:43 AM
Chance S2K's Avatar
That sounds like a good idea. I don't have alot (any) experience in this area but I think that would make for a more efficient and safe break in period.
If your AFR still looks good I may even say just turn the boost all the way down so you can rev the engine out as far as the break in requires, but I'd definitely consult a tuner/builder first before going to ohard into the rev range with an untuned new engine.
Old Dec 17, 2015 | 01:28 PM
davidc1's Avatar
Just to be thorough, I'd use break-in oil as well. Driven oil from Joe Gibbs Racing is good stuff.
http://www.drivenracingoil.com/dro/p...embly-oilshtml
Old Dec 17, 2015 | 01:36 PM
umair's Avatar
Changing the boost wont change the afr. If its off its gonna be off.
Old Dec 19, 2015 | 07:46 AM
geekyjerry's Avatar
And of that you're right, but it will prevent me from hitting boost during break in.
Great advice Folks. Any other tips for the break in, or base map?
Old Dec 19, 2015 | 07:58 AM
Brutus's Avatar
http://www.laskeyracing.com/shop/breakin.htm
he says tow it to your tuner.
steven975
Jun 4, 2011 05:12 PM
S2K_2003
Jul 13, 2010 05:56 PM
EK9MAX
Jun 28, 2010 05:39 AM
greenzj
Oct 14, 2004 03:26 PM
