Synapse Synchronic bov
Old Nov 20, 2008 | 04:22 PM
EternalLx's Avatar
Default Synapse Synchronic bov
Hey guys I just bought a synchronic bov and theres a line that says to hook up to a boost only source..........
am running a kraftwerks high boost kit and am wondering if theres any other way besides welding a new onto the intake piping?
the red line i have pictured below would be a vacuum right?
is the blue line the only way?
Old Nov 20, 2008 | 05:20 PM
Elroy's Avatar
Copy Cat
The Synchronic bov is installed in the same location that the Bosch was. This pic shows where the boost tap is located and the vacuum line originates in the same location as the KW kit although before the drop to the bov, I split the vacuum line into two for both of the ports on the back of the Synchronic bov. You will have to shorten the return line going from the bov to the intake tube.
This just shows the location of the Synchronic bov.
J
Old Nov 20, 2008 | 05:30 PM
EternalLx's Avatar
Haha I wasnt the only one to copy lol.
Did you just drill a hole and twist the brass tee onto the pipe? or is it actually threaded?
Old Nov 20, 2008 | 05:58 PM
jbell's Avatar
Banned
assuming its a decently threaded tee, 10psi shouldn't push it out.
you could also nut the inside of the tee, with some rubber rings to help seal.
and damn elroy. im on a 26" lcd at 1920x1200 and those pics are still huge. lol
i do like your oil cooler relocation though.
Elroy's Avatar
It is threaded!
J
Old Nov 20, 2008 | 07:29 PM
EternalLx's Avatar
Thanks Elroy!
Old Nov 21, 2008 | 05:36 AM
CooperS2K's Avatar
whats the sound difference from stock to this?
Old Nov 21, 2008 | 02:43 PM
EternalLx's Avatar
From what Elroy told its alot louder and it sounds more aggressive compare to the not so loud hardly hear it shifting at 5k wheezing sound of the stock one.
Old Nov 21, 2008 | 03:03 PM
CooperS2K's Avatar
hmmm, if i go KW next month ill keep that in mind
Old Jun 1, 2011 | 12:53 AM
Rob@ReidyRacing's Avatar
Has anyone got pictures of an install on the cold side. I have a Synapse and was wondering how eveyone hooked theirs up
beechx1
Jun 14, 2015 08:00 PM
SilverstonedAP2
Mar 27, 2012 06:31 PM
deathsled
Dec 8, 2009 08:06 PM
nightcrawler7188
Apr 6, 2008 05:47 PM
Patrick Jamex
Feb 1, 2005 11:16 PM
