Synchronic BOV by Synapse Engineering
Old Jun 3, 2010 | 09:39 AM
Spec_Ops2087's Avatar
Originally Posted by JustinC,Jun 3 2010, 08:46 AM
Im curious about your post Spec, if the BOV opens whether on the hot-site or cold side of the intercooler, why would it make a difference, the compressor would be the result of the intercooler piping being completely sealed off, if the BOV is opening and closing properly and the BOV opens and creates a hole in the piping, how can it surge the turbo?
Is it b/c it allows the turbo to spin too freely or b/c of some other issue?
Well the ideal placement for a bov is as close to the throttle body as possible. I can't explain why the synchronic is so fussy about placement but on my IP setup, no matter what I did with adjustments / different springs / different vac sources, it would always surge at full throttle. I ended up returning it.
I know people who have it and works perfectly fine, the only difference is their bov is on the cold side.
The compressor is surging because it wasn't opening fast enough so some of the backed-up air made it to the compressor instead of being blown off.
Old Jun 5, 2010 | 06:47 AM
jaundice's Avatar
My Tial 50 mm is driving me CRAZY with flutter surge at partial throttle and at medium throttle. It only blows off at full throttle lift. I have changed springs and it leaks at partial throttle and will not stay closed unless full throttle. UGHH. I just bought the synchronic last night and will post up differences.
Old Jun 5, 2010 | 07:38 PM
vector01_hungry's Avatar
it works well for me. I have a hi boost kw kit.
Old Jun 6, 2010 | 02:48 AM
s2k.igor's Avatar
Anyone using it with a Vortech Supercharger? Does it work?
Old Jun 6, 2010 | 01:02 PM
m R g S r's Avatar
no one has any complaints about the mounting system?
it seems really flimsy to me with only those tiny set screws. mine has never fallen off or leaked or anything, but the BOV doesn't seem it as is securely mounted to the flange as a BOV that mounts with a Vband or two bolts.....
Old Jun 7, 2010 | 09:57 AM
D-S2K's Avatar
[QUOTE=m R g S r,Jun 6 2010, 01:02 PM] no one has any complaints about the mounting system?
Old Jun 19, 2010 | 07:02 PM
jaundice's Avatar
I installed mine today. HUGE difference over Tial BOV. No compressor surge anymore and no fluttering. Holds boost to 28 osi with no probs and opens instantly on throttle lift. No partial throttle flutter blow off or anything. Absolutely what I was looking for.
As above, new style with internally built port c (boost only) and large mounting screws. Used the adapter for the Tial mount and installed it in 10 minutes. Perfect.
Old Jun 1, 2011 | 12:52 AM
Rob@ReidyRacing's Avatar
Has anyone got pictures of an install on the cold side. I have a Synapse and was wondering how eveyone hooked theirs up
Old Jun 1, 2011 | 05:21 AM
kels_2k's Avatar
good news
can you provide some quick pics.
I currently have the tial 50mm on cold side as you did.
ldiaz
Jan 10, 2014 05:40 PM
g352s2k
Sep 6, 2009 04:27 PM
RichV
Aug 26, 2008 06:49 PM
mr_grand_prix
Dec 21, 2007 04:46 PM
Spec_Ops2087
May 5, 2007 08:57 AM
