Traction Control *AEM ECU*
Yeah its pretty much the same but this actually uses a sensor on a wheel that doesn't loose traction and calculates by the speed for each gear to allow for your boost and performance to be a little more accurate...
Some of the high performance import drag cars are using it especially on tracks that don't have good traction.
Unless it has changed AEM's traction control works off of rate of acceleration...for example if your VSS accelerates faster than what they can normally accelerate under traction then it knows you are getting slip.
my understanding of traction control, at least on the AEM EMS, is that it uses a VSS and isn't very accurate, unless an additional VSS sensor is installed. Which is put on the front wheel if its a rear wheel drive and the rear on a front wheel drive, so it can work out the speed differential between the sensor on the output shaft of the transmission and the actual speed of the vehicle. This makes it much more accurate to control wheel spin on these cars which are still using non-DBW throttle setups.
