Trying to do a 9 -11 psi setup on new swap
Old Sep 23, 2009 | 05:57 AM
  #21
jvu3's Avatar
Originally Posted by AndyFloyd,Sep 22 2009, 06:33 PM
No problem man, if you have any more questions feel free. Want to do it right this time and thats why I want to help so much. I know how it feels to have to re-do stuff right, so props to you.
i agree. thats why im not jumping into anything before i get my preferred set-up. As well if you have a garage, try and DIY on the turbo install. It will help in the long run when you run into problems
Old Sep 30, 2009 | 06:45 AM
  #22
angr2387's Avatar
ok i got one more question.... since i dont have to change the headgasket to a 3mm inline pro headgasket, is it necessary to change the stock headgasket to a new one? i mean it is a used engine im getting so i dont know if it would be ready for boost ? thanks for the help
Old Sep 30, 2009 | 07:01 AM
  #23
HMFIC's Avatar
uh... if you had to break open the motor to put a stock HG.. you might as well do the thicker one..
dont break open the motor unless you are going to put a thicker HG...Alot of folks are still on stock HG like myself...and are pushing ALOT more power than i ever will.
Either make up your mind now for the HG swap to a thicker, or dont break open the motor..
Old Sep 30, 2009 | 07:38 AM
  #24
angr2387's Avatar
oh sounds good, but the original headgasket that on the engine ( engine has 43000 miles on it) should be able to last?
Old Sep 30, 2009 | 08:08 AM
  #25
AndyFloyd's Avatar
yea itll be fine, dont mess with it!
Old Sep 30, 2009 | 08:49 AM
  #26
HMFIC's Avatar
only 43K? dood i'm hitting 99,913 miles as of today..* i actually looked down before getting out the car* and i'm turboed..and have been turbo'd twice..
the motor is completely fine.
Old Sep 30, 2009 | 09:21 AM
  #27
SHEPSS2K's Avatar
Just do a compression test. That will tell u how well the engine is. That low of mileage you should be fine!
Old Sep 30, 2009 | 09:30 AM
  #28
ssjmikeg's Avatar
Originally Posted by angr2387,Sep 22 2009, 05:58 PM
some how the previous owner had 404hp at 19psi
that is what i got out of my kit on a dyno pack 3000 404 whp and 265ftlb mine should be about 430 on different dyno but i called inline pro and they said that was about right on that manifold. at 19-20 psi. i also had 3mm headgasket. but you will make better numbers with the stocker. i think about 13-14psi should weild you 400whp on stocker. from what i have read
Old Sep 30, 2009 | 01:43 PM
  #29
angr2387's Avatar
thanks guys another 500 i save on labor thx
rikhemi
Apr 1, 2011 09:41 AM
91crxdx
Forced Induction For Sale
15
Jun 4, 2010 07:15 AM
xeuxx
Feb 18, 2010 05:43 AM
BlitZs2000
Cars for Sale
Jul 4, 2008 02:29 AM
slammo
Oct 19, 2006 09:36 AM
