TTS RACE SUPERCHARGER CONVERSION
Old Mar 5, 2014 | 05:51 PM
  #121
jaundice's Avatar
I a really interested in making a bottom mount kit work on a LHD car. I have a track only car with no AC and am very interested in this setup
Old Mar 6, 2014 | 01:09 AM
  #122
s2kjn's Avatar
Is anyone going to run full boost on their stock motor using the 91?
Old Mar 6, 2014 | 04:32 AM
  #123
S2G4life's Avatar
When speaking with Richard, he said 15 psi was the most boost he was comfortable with running on stock motor. FYI
Old Mar 6, 2014 | 11:00 AM
  #124
s2kjn's Avatar
Oh really? He told me that I should be fine to run full boost....maybe because I'm running e85?
Old Mar 6, 2014 | 11:06 AM
  #125
xLostx's Avatar
There are other customers of theirs running e85 and full boost. There's other guys on here with 500,600 hp setups off 100% stock engines. Depends on if you're going balls to the wall non stop, that might play a factor in how long your motor will last.
Old Mar 6, 2014 | 11:18 AM
  #126
06S2k07Si's Avatar
Yea...odd... The one in his video is 18psi on a stock motor.
Old Mar 6, 2014 | 11:28 AM
  #127
s2kjn's Avatar
Yeah I did a bit of a search and found this thread:
https://www.s2ki.com/s2000/topic/923...can-they-hold/
However there doesn't seem to be one that addresses the amount of boost the F20c can handle, unless I'm going blind :s
Old Mar 6, 2014 | 12:22 PM
  #128
S2G4life's Avatar
Wow. Maybe I steered him into that recommendation. Could it have something to do with being in Texas with plenty days of 100-110 degree weather? Sorry for the noob question, but I planned on just putting this and a clutch in. I want to do spring retainers and rollers at a later date. Will I be safe doing this? What all would you do to your motor to run 18-20 psi safe, keep it a reliable daily driver, and being in texas with plenty of heat?
Old Mar 6, 2014 | 12:33 PM
  #129
s2000442's Avatar
I think Richard is right. On pump gas 14-15psi is usually the maximum level people run. His 18psi run I believe he starts to cut timing to stay safe but that is not what I would do. You can safely run 18-20psi with E85 or race gas. I was running an 18-20psi ptuning kit making 560whp on E85 with no problems. However, I don't beat on my cars. It depends on how you drive. The engine is strong and can take boost.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Old Mar 6, 2014 | 12:59 PM
  #130
s2kjn's Avatar
So all that pier and I can't put my foot down
