Turbo head build, light weight vs aggressive cams
Old 07-11-2018, 04:43 PM
F1TwoThousand's Avatar
Do aftermarket cams for s2k have same cam profiles pre-vtec? Will it drive exactly like stock cams say until 3k rpms and then switch over to very aggresive cam profile? Cant seem to find the answer. Oh and what size are stock s2k radiator fans? Beel looking for that info for days
Old 07-11-2018, 04:44 PM
Hatrick that is an incredible looking dyno graph, thank you for sharing!
Old 07-11-2018, 04:54 PM
So if this is the stock vs bc cam dyno this means the stock and bc cams have the exact idle and low rpm drivability but the bc cams are on v-tec plus steroids? This seems too good to be true
MARK AUS S2K (07-11-2018)
Old 07-11-2018, 05:10 PM
MARK AUS S2K's Avatar
Where did you find that graph mate?
Old 07-11-2018, 05:29 PM
Hatrick posted this link
http://www.briancrower.com/makes/honda/f20cf22c.shtml
go to page scroll down to bc cam stage 2 (turbo) click on graph
Old 07-12-2018, 12:59 PM
Charper732's Avatar
Originally Posted by hatrickstu
My car seems to work pretty well with the NA BC Stage 2's
AP2 crank, roughly 9,500rpm with full Ferrea valvetrain. Edit: forgot I actually have the BC springs/retainers.
Did you play around with the cam timing on this or this is on stock cam gears?
Old 07-13-2018, 05:13 AM
hatrickstu's Avatar
Stock cam gears
Old 07-14-2018, 12:08 AM
DavidNJ's Avatar
What is the cam timing? Like pistons, turbo cams are different. More separation, less overlap.
Unfortunately I can't find anyone listing their K24 turbo cam specs accurately. However, the Kelford T-202C cam for the Supra, 228/232 at 1mm, lame 9.9mm lobe lift because the 31mm flat tappet buckets can't compete with Honda's roller rockers, has the exhaust centered on 116°BTDC and at 1mm at TDC. Intake is at 1mm at 7° BTDC. Less overlap. With dual VTC it would be programmed to overlap at no/low boost. For some reason Kelford isn't listing their K24 cams and GSC doesn't have any. However, an H22 has 108/115 centerline, 111.5 separation for turbo, 104/104 for NA.
y0itzCARL
12-02-2010 04:32 PM
hypforlife32
07-27-2010 06:01 AM
VashRacing
09-18-2007 09:19 PM
Gunshow
06-06-2007 05:45 AM
B.C.
05-12-2006 09:07 PM
Quick Reply: Turbo head build, light weight vs aggressive cams
