Turbo spool point/revs
Old Nov 6, 2013 | 11:02 AM
  #21
riceball777's Avatar
5700rpm is not right. thats way to laggy for a 35r
i have a gtx3576r with the t3 .63ar hotside running on a stock 2.0 f20c and i get full spool of 12psi bu about 4,600 rpm. This is with a track forged sidwinder manifold. I know i dont have a standard 82mm wheel gt3582r but i doubt that it should spool that much slower than mine.
Here is my boost plot. This was on a 4th gear pull.
Old Nov 6, 2013 | 11:06 AM
  #22
herecomesboost's Avatar
^Benton, are you using a solenoid to regulate boost pressure or are you on the wastegate?
Old Nov 6, 2013 | 11:40 AM
  #23
s2konroids's Avatar
Had a bit of help tbh from what I can see/read full boost of 20 psi at around 5700 rpm is about right. My exhaust isn't restrictive and I run a screamer pipe - not that that will help massively.
I seen another car on the dyno with a pretty damn similar setup, a Kings performance 6262 precision turbo setup and the spool between both cars was roughly the same.
I've played with the tables and it appeared in some logs I managed to drop the full spooled point by around 200 rpm but on a different run with the same boost it went back to normal I suspect temperature plays part in this.
When the turbo fully spools it comes in with a lot more conviction and spins the wheels easier unfortunately had rubbish weather and haven't been able to do any more testing/tweaking.
Gtx is bound to help spool for sure, I'm sure that was one of garretts motives from I read.
Joey is running more boost than me but he said when his car was rough the same as mine it spooled around the same point.
I just don't know.
Old Nov 6, 2013 | 11:43 AM
  #24
s2konroids's Avatar
Originally Posted by ScienceofSpeed
for comparison:
ScienceofSpeed TS-MAX GT3582R @ 19 PSI full boost at 4200 RPM (peak power was 512 WHP):
http://scienceofspeed.com/products/e...2R-E85_800.jpg
more info:
http://scienceofspeed.com/products/e...harger_system/
That spool time wouldn't surprise me since you run a twin scroll and log manifold but that's damn good figures.
Old Nov 6, 2013 | 07:08 PM
  #25
I'm running a 7psi spring in the wastegate and the boost is controlled with a 3 port Mac boost solenoid via the aem v2
Old Nov 8, 2013 | 07:07 AM
  #26
s2konroids's Avatar
Just an update to this spent a hell of a lot time and managed to get it fully spooled at 5200 rpm does this sound better?
I think I could lower it down even more say 100 rpm but with a hell of a lot time spent and lots of road runs.
Hard to keep spool good, not over boost or oscillate and not come in with a thump as spins tyres easily.
Charper732
Jun 9, 2017 06:56 PM
s2konroids
Sep 22, 2014 04:38 AM
AFs2k
May 1, 2010 02:22 PM
freshs2k
Jan 12, 2010 06:34 AM
batikan
Nov 17, 2006 12:03 PM
