Twisties with FI
Originally Posted by o'malley_808,Feb 22 2011, 06:07 PM
Precisely, so when I get on the gas coming out of a corner according to your theory my turbo may spontaneously spool up at 2500 rather than the usual 3500rpm?
Didn't think so...
And since when does a turbo vehicle not make the same power every time at 7000 rpm also? Whether S/C or turbo its dependent on throttle position.
Didn't think so...
I am talking about the spool time, that means that even if you WOT @7k rpms you will NOT have the same whp as shown on a dyno until the turbo spools which could be several hundred rpm later. there will be a little bit of lag which varys depending on how fast the turbo is already spinning.
Originally Posted by 06S2k07Si,Feb 21 2011, 07:00 PM
Perhaps I missed it but, IMHO I believe that the one thing that I think that really needs to be discussed is the amount of time from the moment you open the throttle until there is boost and or acceleration (spool time or turbo lag perhaps?). Ideally when you are driving through corners, specifically mid corner, you want to have very good control of that time between the actual throttle movement and boost/acceleration delivery. Having no experience driving a turbo'ed S2000 I can't say, but after spending some time driving a completely stock BMW 335i, my S/C'd S2000 has quite a bit more linear delivery than the 335i.
Brian
Brian
Originally Posted by soulicious,Feb 22 2011, 03:26 PM
OP: Just go Ptuning for now. Drive your 120 miles of twisties numerous times (even during extreme heat conditions) in one sitting, go to your local small road course/autocross, and then report back any issues (accidents, heat issues, high maintenance, headaches, etc) that you may have.
I win!
I win!
Relax, I am sorry about the slow car comment...I know you have a nice setup! and it was nothing personal against you. A well setup turbo system can be reliable but they have gotten a bad rap due to heat issues and people cutting corners on heat management, no oil coolers etc so the SC guys were more reliable. I dont think PTuning is trying to sell their kit in this thread, they dont need to, the quality speaks for itself. They are just trying to educate people that turbos can be a reliable and effective alternative if you would like to track the car.
ok let me put my .02 in this. I have have turbo experience from my built civic (gt3076, fast spooling turbo right? and making 450 hp). From what I understand the issue at point is lag. Lets say were getting ready to pull out of a corner and we're at 7000 rpms and at full vacuum, smash the pedal and what happens? depending on which gear, 2nd in this case, I start to pull out at a measly 150 hp, but very quickly I build boost, spin, and under steer like crazy. I have tried to control the boost with my right foot, it's very hard to do with a quick spooling turbo, because at full vacuum and 7000 rpm, it's very hard to get 10 psi out of 24 psi quickly (like in a race or a time attack). What I do is pull out in 3rd, full throttle. It's not the fastest way, but I don't get paid to worry about that.
I have no experience with superchargers, do they exhibit that little bit of lag? Since they run off engine speed, not exhaust pressure, at full vacuum and 7000 rpms, are we seeing 9psi in the charge pipes?
If what I'm hearing by some of the member post/salespeople in this thread, we have turbos in the max SC power range of 450-500whp that have no lag and controlled directly by your foot, seamless just like a SC, if this is true then it would be hugely beneficial, these kits however would still be following the characteristics of what makes an SC the natural choice for road racing, and not leading it. Ultimately your suspension and tire set up is going to dictate what you can make use of in the twisties. I run custom widened rpf/weld craft rear 11.5" wheels with 295/17's with Kuhmo XS extreme summer compound tires and I can still induce plenty of over steer and spin with my 375whp/230trq SC. If I threw on some Hooser R comps, I could make use of a 500whp/300trq set up, make it stick and run fast. A 500whp/400trq Turbo with a few unpredictabilities or surprises doesn't sound like the winning approach, but that's just me. We are talking about Turbo/SC in a 2800 or less S2000 after all.
Transient response of a turbo will never, EVER match a S/C, unless your piping essentially runs from the turbo to the intake manifold.
/thread.
The power is just not as predictible.
How many RWD turbo sports cars are there in production today? I can think of one: Carrera GT2. Everything else I can think of is considered an exotic. Now look at the AWD turbo sports cars (sti, evo, porsche, to name a few). I wonder why that is.
Even bringing in non-sports cars, I wonder why AMG decides to cap off the torque in some of their beasts....
/thread.
I'll make it easy. Road racing with an S2000= SC. Drag racing an S2000= Turbo
