The Ultimate GReddy Turbo Kit Thread
Old Nov 7, 2011 | 12:06 PM
  #1331
RedSunS2K's Avatar
Originally Posted by S2KCHRIS305
what brand makes 10w40 . i dont think mobile 1 has a 10w40
I bought Amsoil 10w-40. Ordered online though. Can anyone chime in on good 10w-40 that is actually sold in stores?
Old Nov 8, 2011 | 07:29 AM
  #1332
S2KCHRIS305's Avatar
Also whens that ram horn manifold comming . Il be installing my kit soon once I get my clutch would love to be one of the first with the ram horn . Lol
Old Nov 10, 2011 | 09:27 PM
  #1333
I got a question my kit came with the long filter walbro fuel pump. The first page on this page says its the wrong one . What u guys think ?
Old Nov 13, 2011 | 10:12 AM
  #1334
bump . anyone ?
Old Nov 14, 2011 | 08:07 AM
  #1335
Nyther's Avatar
bump . anyone ?
you need the short one thats NOT angled upwards, but hangs in a 90 degree angle on the bottom.
Re-use your old sock otherwise your fuel gauge will give you inaccurate date. Or try to get the right one!
Old Nov 14, 2011 | 09:38 AM
  #1336
Where do they sell the right one?
Old Nov 14, 2011 | 12:18 PM
  #1337
lobuck's Avatar
Does anyone know how far the wastegate should be able to move. I have the actuator off and the waste gate moves sort of freely and only about 40-45 degrees. Should it be able to open all the way out? Do I need to oil it or something?
I can't open it like this wide.
Old Nov 15, 2011 | 07:25 AM
  #1338
Nyther's Avatar
You can get the right sock perhaps at ebay.. i got mine supplied with my HRC 255LPH fuel pump...
I think its normal that the wastegate flapper doesnt open 90 degrees when the downpipe is ON.. it should hit the downpipe at around 45 degrees...
if you have the turbo off the car, you should better port the wastegate 1-2mm bigger ( make sure the wastegate flapper will still cover the hole, even with the sideway play it has.. ) so you won't have a big boost creep issue anymore and the flow will be better..
Old Nov 15, 2011 | 11:41 AM
  #1339
lobuck's Avatar
They sell the filter sock at honda. I just ordered one.
Yep, the turbo isn't installed yet. I was thinking of porting the wastegate but that flapper won't move all the way down Like in the picture. Am I supposed to put more force on it, I don't want to break anything.
Old Nov 15, 2011 | 04:31 PM
  #1340
So I could use the pump just change the sock ?
