ULTRAFAST HELP NEEDED-HOW TO WIRE?
Going to fire up the engine to check if the instalation of the LOVEFAB kit is ok in 2 HOURS, need to wire the injectors and RESISTORS till then before the tuner comes.
I have red and brown on each injector clip (came from FORD) and yellow/black plus a color on each injector OEM wire:
P>L>E>A>S>E> help only if you are 100% sure where to wire the resistors. Inline with the ground or inline with the signal?
Originally Posted by Slows2k,Jul 23 2005, 08:48 PM
The injector plugs wire in the same orientation as the original plugs.
You've double posted in UTH, please only the same topic in 1 forum.
Anyway, you can close it now, the problem is solved
