Upgrading the Boost
Originally Posted by FF2Skip,Jun 15 2005, 03:42 PM
Where did you get that info from? I looked on their site and found nothing.
What diameter is the 10lbs pulley?
Again, finding a belt that can be sufficiently tightened may be a trick(for the 3.25" pulley)... dunno.
What diameter is the 10lbs pulley?Again, finding a belt that can be sufficiently tightened may be a trick(for the 3.25" pulley)... dunno.
Dava you cna seve money
SOS is really a expensive shop
Regarding the belts have a look here
https://www.s2ki.com/forums/index.php?showtopic=254159
- order the pulley from ASP, I rather prefer steel
- Buy the 550 cc with clips from our sponsors
- There are a few AEM used in the FS forum
Newest Update -
A local friend of mine is placing an order with ASP tomorrow for a custom Steel 3.25" Pulley so I will be having him order a second one for myself.
With the fact that I will be going with a 3.25" Pulley I will be opting to go with 650cc injectors, so now it comes down to locating a board sponsor to purchase the injectors from.
S2000 Europe,
I have visited the link that you supplied, but nothing is stated on a 3.25" Pulley. AusS2000 had recommended a 39" Belt for a 4" Pulley, a 38" Belt for a 3.5" Pulley, so I am guessing that i'll be attempting to locate a 37" Gatorback Belt.
In regards to the AEM EMS, speaking with a friend I understand Horsepowerfreaks offer a great deal on the 1052-U so unless I find a great deal around the time I plan to move further, I will purchase from them.
S2000 Europe,
Originally Posted by kane.s2k,Jun 15 2005, 02:32 PM
get the aluminum one
Old age is coming early for me.
Originally Posted by FF2Skip,Jun 15 2005, 07:38 PM
Granted, aluminum would offer less rotating mass, but is there any other reason for choosing it over steel? I've heard folks(before this thread) debate the merits of both, however, cannot recollect any of the points!
Originally Posted by Sideways,Jun 15 2005, 10:15 PM
The only benefit to steel is it tends to grip the belt better and decreases the belt slipping to a very small degree. The aluminum ones work fine in our applications and weigh considerably less. Are you sure you want steel?
I don't know why Chad(Black Nugget) keeps referring to this "friend." We're not friends.
Sideways, did you skip over the 11lbs pulley and go straight to 13lbs(now 16 lbs if I read right) after the head work?
RZFD,
Try and keep the thread clean so it can remain open - it contains some good info that can benefit others!
I went with a Steel ASP on their advice to help and reduce slippage!
I have a 14 pound pulley which measures 3 inches where the belt rides.
I have a set of RC 650's for sale if you are interested - PM me
$300 shipped and insured
Two 3.25" pulleys ordered(one for BN and one for me) and to be made by ASP.
Now to find the right size belt.
FWIW, we ordered the aluminum ones at the recommendation of Lee at ASP. Our application, just as Sideways mentioned, will be fine without having to go to steel.
