VitTuned S2000 Project Begins
Originally Posted by VitViper' timestamp='1419958747' post='23451205
The clutch feels awesome. The pedal is a bit heavier than stock, but the engagement is smooth, doesn't chatter, and no BS. It's still very grabby (it is a twin..), but you still have plenty of control with your left foot. I street drive the car (sshh don't tell AEM lol), and don't hesitate at all to take it for a milk or baby formula (or diapers, haha) run.
Also, approx. where on the rpm range on e85 do you hit target boost? (say 17psi)? Are you using the oil-less CT5862? Haven't heard much about them since Comp announced they made them.
I'm on the Exedy twin now.
What gear? 4th gear 17psi is made before 5k rpm. Oil still, oil-less is higher cost and not really recommended on a street car unless turbo placement is an issue.
How do you like the twin? Do you think you should've gone there is the first place? I'm just now debating between this turbo and a GTX3576R. It'll be on E85 (it's everywhere where I am), fast spool and transient response are the most important. I would like over 500hp too though
"E85 cold starts are hard"
https://www.youtube.com/watch?v=-I06nALiBe8
Lol
Fuel system is now a set of Deatschwerks 2150's with two DW 340's in tank using the full blown hanger and a custom dual pump relay harness I put together. Blurry picture of incomplete relay harness.
Comp CT4X-6467 is in the mail, I get it tomorrow.
Lol
Got the Comp CT4x-6467 .82a/r T3 turbocharger in and it went onto the #S2000 immediately. This turbo flows VERY nicely, and I could have revved the motor out past 9k while making power. Over 130whp gain @ 9000 rpm over the 5862 that was replaced, granted initial power onset was about 700-800 rpm later.
I had to drop to 5th gear as the 3000 series Dynapack pods maxed out in 4th gear ~600whp, and 5th gear reads 5% low in comparison. 33-34lbs netted ~708whp and 535ft lbs of torque, corrected for the gear change we're at about ~730-740whp.
But the best part -- the turbo isn't done yet. I had her spinning 38lbs and she loved it -- unfortunately the 3000 pods didn't like anything more than 34lbs. With more boost this is no doubt a 770-780whp car now, which is not bad at all for a T3 frame turbo!
Lol...
Comparison vs the 5862, both 5th gear plots so it's a 1:1 comparison.
Lol...
Better yet, why? The oil filter relocate that comes with the PRL kit has 2 free ports, which is where I run the oil temp and oil pressure sensor for my AEM (you could do oil pressure and turbo feed from it if you really wanted to).
As for vacuum block, PM me and I can link you to a low cost one that fits neatly into the brake booster line by the firewall.
Originally Posted by skinsfn36' timestamp='1427052265' post='23550280
Vit, do you think the PTuning Oil Distribution/Vacuum block would fit with where the turbo is located on this kit?
Thanks!
