Wastegate cracks at idle? is this right
Old Jul 18, 2010 | 03:14 PM
JuicedS2K's Avatar
Default Wastegate cracks at idle? is this right
When the car is idling is the wastegate supposed to be cracked a little bit and sound like an exhaust leak? or is that only at WOT?
Old Jul 18, 2010 | 03:34 PM
s2kswe's Avatar
What does "cracked a little bit" mean?
- The WG itself should be quiet under all circumstances.
- The WG should be closed at idle if there is a spring inside it.
Old Jul 18, 2010 | 03:58 PM
MaseEng Nick's Avatar
bad seal between the wastegate and the manifold?
Old Jul 18, 2010 | 04:00 PM
godmachine's Avatar
diaphragm got pinched when installing the spring ?
Old Jul 18, 2010 | 04:56 PM
StocS2k's Avatar
Did you reuse the same gasket(38mm)?
Look like your not selling Good Stuff man!!
Old Jul 18, 2010 | 05:20 PM
teamvalorracing's Avatar
no, it should not be open at idle at all. it takes pressure to open it. and since you are in vac, thats not possible. so either the gasket gave up or the wg bolts came loose.
Old Jul 18, 2010 | 07:03 PM
JuicedS2K's Avatar
Well my friend installed it and i trusted him, and just realized he never installed the valve seat, this could be the reason correct?
Old Jul 19, 2010 | 02:04 AM
s2kswe's Avatar
Doh! Yes if you have the dumptube to atmosphere and the valveseat is gone, it will sound like an exhaustleak. Spank your friend pls.
Old Jul 19, 2010 | 03:54 AM
lol! yeah, that'll do it! how long have you been riding like that? that makes it super tough for the turbo to do its job.
how can you forget to install the seating ring? lol
Old Jul 19, 2010 | 05:22 AM
JuicedS2K's Avatar
thanks guys, im gonna smack my friend when i see him, he can build a 800 whp DSM eclipse, yet forgets the valve seat.
dsddcd
Jun 1, 2019 07:53 PM
japancrx90
May 18, 2011 01:45 PM
-LAW-
Florida For Sale
Aug 23, 2010 06:57 PM
P-CarDriver
Dec 19, 2009 03:54 PM
